8 members (Bunny, Topline123, MATTMOG, Phil63, CooperMan, RichardV6, chanteclair, MJF), 332 guests, and 9 robots.
John V6 69
DaveW 67
+8Rich 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Topics48,343
Posts813,019
RedThree
Hi Iam new to this forum.Had my 2007 +4 for 5years and do my own maintenance. 5year ago I repaired the tool tray and have just had to do it again. I am looking to improve what will be an old problem to you all i.e the diff hitting the tool tray when I manage to find a significant pot hole..New springs and AVO’s were fitted 4 years ago and improved the situation a little.
I seem to have two options :-
1) Add bump stops to the shock absorber rods
2)Add the spring assisters detailed in Dave W article in February Miscellany
Can anyone advise :- a)which is most effective ?.
b)Where I can obtain the Spring Assisters in Dave’s article
Online NoMood
As you have tried tackling the problem at source, i.e. new springs I would go with the progressive bump stops. Rog of this parish makes them.
You could also make your own custom tool tray with both greater clearance where needed and capacity.
Another vote for the fabulous bump stops from Rog.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 5
RJW Offline
I fitted the bump stops more than a year ago. They are very effective.
Bob.
Yes they work well
2025 MG ZS EV aka Trigger
+1, best addon ever.
Nick
CBY Offline
The tool tray is not symetric and some place are deeper. Check it vs the diff and if necessary turn it 180°, you can earn some centimeters.
Regards
2005 PLUS 4
Great add on, no more crashing from the rear end - should be fitted as standard
The fact that both my Morgans have Rog's assists says it all really. Most cars use some sort of upward movement limiter.
Get the gap right and the bangs vanish.
HJF Offline
I’m sure I recall that my MG Midget and Mk2 Escort had such. Seems wrong that Morgan are relying on the bodywork to act as a bump stop.
