1 members (TBM),
290
37
Topics48,345
Posts813,037
Posts: 4 |
Hi Iam new to this forum.Had my 2007 +4 for 5years and do my own maintenance. 5year ago I repaired the tool tray and have just had to do it again. I am looking to improve what will be an old problem to you all i.e the diff hitting the tool tray when I manage to find a significant pot hole..New springs and AVO’s were fitted 4 years ago and improved the situation a little. I seem to have two options :- 1) Add bump stops to the shock absorber rods 2)Add the spring assisters detailed in Dave W article in February Miscellany Can anyone advise :- a)which is most effective ?. b)Where I can obtain the Spring Assisters in Dave’s article Steve
Posts: 7,922 Likes: 217
Posts: 7,922 Likes: 217 |
As you have tried tackling the problem at source, i.e. new springs I would go with the progressive bump stops. Rog of this parish makes them. ![[Linked Image]](https://www.tm-img.com/images/2020/03/27/P1050465.jpg)
You could also make your own custom tool tray with both greater clearance where needed and capacity.
Posts: 5,223 Likes: 123
Posts: 5,223 Likes: 123 |
Another vote for the fabulous bump stops from Rog.
Posts: 312 Likes: 1
Posts: 312 Likes: 1 |
I fitted the bump stops more than a year ago. They are very effective. Bob.
Posts: 26,748 Likes: 419
Posts: 26,748 Likes: 419 |
Posts: 3,665 Likes: 43
Posts: 3,665 Likes: 43 |
Another vote for the fabulous bump stops from Rog. +1, best addon ever. Nick
Posts: 373 |
The tool tray is not symetric and some place are deeper. Check it vs the diff and if necessary turn it 180°, you can earn some centimeters.
Regards 2005 PLUS 4
Posts: 33 |
Great add on, no more crashing from the rear end - should be fitted as standard
Posts: 21,868 Likes: 167
Posts: 21,868 Likes: 167 |
The fact that both my Morgans have Rog's assists says it all really. Most cars use some sort of upward movement limiter.
Get the gap right and the bangs vanish.
Posts: 150 |
Great add on, no more crashing from the rear end - should be fitted as standard I’m sure I recall that my MG Midget and Mk2 Escort had such. Seems wrong that Morgan are relying on the bodywork to act as a bump stop.
