8 members (RichardV6, BobtheTrain, Michael H, John Winn, MartinB60, Grumpy2, teknome, mph),
258
Topics48,343
Posts813,023
Posts: 100 |
The accessory drive belt dips in oil to reduce friction and noise, sounds horribly familiar as a fix to an issue ? It's the primary drive, or cam drive that is "belt-in-oil", which is what nippymog probably meant as a fix to a familiar issue...
Scott
2018 M3W 1995 Porsche 993
Posts: 1,562 |
The accessory drive belt dips in oil to reduce friction and noise, sounds horribly familiar as a fix to an issue ? It's the primary drive, or cam drive that is "belt-in-oil", which is what nippymog probably meant as a fix to a familiar issue... It was indeed , my mistake, thanks for pointing it out
Posts: 2,062 Likes: 57
Posts: 2,062 Likes: 57 |
When I look at the inner reinforcement/ structure of the hood in the background, I wonder how many parts are still being manufactured at MMC...
Edit: "inner boot lid".......
Posts: 1,773 Likes: 19
Posts: 1,773 Likes: 19 |
When I look at the inner reinforcement/ structure of the hood in the background, I wonder how many parts are still being manufactured at MMC... I was looking for a hood for the Super3 but realise you meant boot lid.
Sorry from Germany -I just just edited my post..
Posts: 1,015 Likes: 1
Posts: 1,015 Likes: 1 |
That really is a very different animal to our 5-Speeders. That complete engine/suspension unit and how it bolts up to the monocoque is very modern road-car thinking althoug it has been used in hi-end motorsport for years. Audi famously had a 'rear module' spec'd as a single part-number to all intents and purposes, used in their earlier Le Mans models (R8, R10, R15 etc). When they had a failure of some sort - be it suspension, gearbox, engine malady for example - rules permitted them to change that single component, handily fixing everything in one hit - or something like that anyway. The rigidity of that engine/suspension unit will be absolute and aside from a potentialy higher CofG, I suspect the handling will be superb, with none of the interesting traits our cars have shown throughout their lives. Whether that makes character is personal opinion, but I expect those first Press Drives in the near future will rave about it. Having said that, my car was such a hoot at Goodwood this week that the old " If it ain't broke...." tagline is firmly flying around my head right now
Posts: 423 Likes: 2
Posts: 423 Likes: 2 |
With no crush zones apparent, I would be concerned about front end impact forces being driven back to the passenger and driver by those rigid castings.
Lance 1981 Plus 8 2016 Three Wheeler 2022 Corvette Stingray Convertible z51
I view my overall safety in much the same vein as riding a motorcycle, which could end badly in the case of any shunt, whichever way you look at it in such a small and vulnerable vehicle. I take your point though and it would be interesting to know what hoops MMC have had to jump through in terms of Homologation for the new car - things are probably an awful lot tighter now than they were in 2011 when they aligned the then new M3W to the regs?
Posts: 49 Likes: 1
Posts: 49 Likes: 1 |
With no crush zones apparent, I would be concerned about front end impact forces being driven back to the passenger and driver by those rigid castings. You should consider it a motorcycle with more protection, rather than a car with less
Posts: 49 Likes: 1
I view my overall safety in much the same vein as riding a motorcycle, which could end badly in the case of any shunt, whichever way you look at it in such a small and vulnerable vehicle. I take your point though and it would be interesting to know what hoops MMC have had to jump through in terms of Homologation for the new car - things are probably an awful lot tighter now than they were in 2011 when they aligned the then new M3W to the regs? Since it's homologated as a motorcycle I don't think it needs to comply to any crash test
