6 members (+8Rich, Morganmike, High Hamster, deano, RichardV6, Bobajobbob), 243 guests, and 89 robots.
+8Rich 78
Topics49,872
Posts837,704
Rudolf
#744657 15/06/22 09:00 AM
asmair Offline OP
Good morning,
I am looking for advice regarding tyre rotation including the spare wheel, wire wheeled 1997 Plus 4 T16. To create even wear on all 5 tyres, avoiding the spare reaching an age where it has done no miles and has reached old age, I was wondering if there was an order of movement. I tried searching the forums but could not find any advice. What is the accepted rotation pattern please?
Supplemental question: Whilst the wheels are being rotated, should I change the" hammered on to the outside rim" balance weights for the stick on variety applied to the inside rear of the rims?
Thanks in anticipation
Alistair
asmair #744666 15/06/22 10:32 AM
JCK Offline
Just Google tire rotation sequence with spare.
JCK
1960 Plus 4 Roadster
JCK #744697 15/06/22 02:05 PM
and be aware that the pattern is different for front-wheel drive and rear-wheel drive.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
asmair #744708 15/06/22 02:49 PM
Online NoMood
Was rotating my rear tyres with spare starting at 5,000 then 10,000 miles until punctures messed up the system. Last time I checked all five I just put the one with marginally least tread in spare location.
asmair #744709 15/06/22 02:54 PM
While m/cycles tyres tend to have tyre treads designed to rotate in one direction only, that is not so much the case with car tyres though in the cases of the more sporty type of tyre there tends to be a easily spotted arrow determining the direction of rotation. I suspect the M3W may use m/cycle tyres..
asmair #744719 15/06/22 03:36 PM
You need to change them every 6 years or so. I have never had a tyre were out on a Mog & I do 6 to 8k p.a. Leave them as they are.
John V6 #744810 16/06/22 08:52 AM
Black Rat
Black Rat
Methinks you drive too carefully hide
Keith
2013 narrow bodied + 4 Ruby.
