Posts837,284
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
But.... Can I retrofit this new "improved" bevel box? At the launch we were told that externally and the mountings of the new bevel box were the same for the Super 3 as the current Quaife version, and they certainly looked the same.
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
I guess the drive sprocket may not be the same, but this should be 'easily' swapped. Interesting to note that (on this prototype at least) there are no guide plates. ![[Linked Image]](https://www.tm-img.com/images/2022/06/15/S3-BB.jpg)
Andy
Posts: 10 |
Posts: 1,562 |
Even the drain plug placement on the new box seems the same - partially hidden behind a mounting plate, doh. There also appears to be a plate under the drain placed nicely to catch drips ! tidy. Either that or it will spread lost oil everywhere as you move off .....
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Even the drain plug placement on the new box seems the same - partially hidden behind a mounting plate, doh. There also appears to be a plate under the drain placed nicely to catch drips ! tidy. Either that or it will spread lost oil everywhere as you move off ..... Maybe the thought was for MMC to remove the BB to drain the gear oil? Could not add to much to the cost of maintenance could it? :-)
Posts: 2,049 Likes: 12
Sir S1'a'lot Talk Morgan Expert
Posts: 2,049 Likes: 12 |
Just saw this on Instagram The car sounds epic. Very air cooled 911
2002 Aero 8 S1 2023 Plus 4 (woman’s)
Posts: 120 Likes: 1
Posts: 120 Likes: 1 |
Just saw this on Instagram The car sounds epic. Very air cooled 911 Just seen it a few minutes ago - exactly my thoughts! It will be an absolute fun to drive it hard around the mountain passes of Switzerland. WOHOO!
Posts: 148 Likes: 11
Posts: 148 Likes: 11 |
Does the Super 3 have the same brake parts, master cylinder, etc. as the CX cars? Just a thought.
John R Marchant Plus Four JT10MOG "Florence"
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Autocar's report in the magazine his week was equally positive. I shall drive one. As soon as there are dealer demonstrator machines.
