4 members (Alan Patterson, John V6, Paul2408, Luddite), 235 guests, and 53 robots.
Posts837,251
Rog Offline OP
Just thought I would quickly post this for the record….
Had this really annoying faint tinkling noise coming from the off side front suspension for a week or so. Couldn’t see anything obvious so decided to start pulling stuff apart today. Fortunately I didn’t have to do very much before finding it in the damper. The Bilstein has a large washer that seems to support the dust cover. The washer appears to be sat on a wire rod clip but somehow had fallen to the other side and was just rattling around on the damper shaft.
All sorted and silent again, at least for now woohoo
Roger
I wonder if a drop of Loctite would hold it in place ?
Rog Offline OP
I think the hole in the washer was a bit generous. Maybe if it does it again I will slip a smaller better fitting washer underneath the larger one. I suspect the top fixing might had originally been a tad over torqued too loading it up.
Roger
X
X
That‘s german engineering. Take a cheap washer, which doesn‘t fit…
Change the construction for fitting a (also cheap) circlip - problem solved.
Main benefit: problems in future are in sight, so sell a new set of dampers.
Greets René
2018 plus4 (sports green)
