8 members (JMcL, Arwyn Williams, DPEvans, GrumpyPa, DaveW, JohnHarris, +8Rich, Burgundymog),
220
60
Posts837,257
Posts: 1,702 Likes: 35
Posts: 1,702 Likes: 35 |
Just thought I would quickly post this for the record…. Had this really annoying faint tinkling noise coming from the off side front suspension for a week or so. Couldn’t see anything obvious so decided to start pulling stuff apart today. Fortunately I didn’t have to do very much before finding it in the damper. The Bilstein has a large washer that seems to support the dust cover. The washer appears to be sat on a wire rod clip but somehow had fallen to the other side and was just rattling around on the damper shaft. All sorted and silent again, at least for now  ![[Linked Image]](https://dl.dropboxusercontent.com/s/3brzue5z5zdofwo/tinkle.jpg)
Roger 2011 Plus 4
Posts: 8,658 Likes: 487
Posts: 8,658 Likes: 487 |
I wonder if a drop of Loctite would hold it in place ?
I think the hole in the washer was a bit generous. Maybe if it does it again I will slip a smaller better fitting washer underneath the larger one. I suspect the top fixing might had originally been a tad over torqued too loading it up. ![[Linked Image]](https://dl.dropboxusercontent.com/s/e6d2li39qpyu75a/tinkle2.jpg)
Roger 2011 Plus 4
Posts: 1,065 Likes: 23
Posts: 1,065 Likes: 23 |
That‘s german engineering. Take a cheap washer, which doesn‘t fit…
Change the construction for fitting a (also cheap) circlip - problem solved.
Main benefit: problems in future are in sight, so sell a new set of dampers.
Greets René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
