SORN
New
Topics48,375
Posts813,508
Members9,215
Posts: 1,673 Likes: 25
Posts: 1,673 Likes: 25 |
Yes, you're right. It would be great to be able to rifle through their parts bins to find something that would fit. These two may be likely candidates? ![[Linked Image]](https://tm-img.com/images/2022/07/24/Screenshot-2022-07-24-at-19.54.15.png) ![[Linked Image]](https://tm-img.com/images/2022/07/24/Screenshot-2022-07-24-at-19.46.34.png)
Andy
Posts: 35,802 Likes: 476
Posts: 35,802 Likes: 476 |
Could this firm be of any help ? Maybe worth sending them a duff one as a pattern.
Posts: 945 Likes: 16
Posts: 945 Likes: 16 |
Could this firm be of any help ? Maybe worth sending them a duff one as a pattern. Looks terrific too! Plenty of choices! But same complaint: they don't put the dimensions of their sensors in the web page, so it's a total gamble to find the one that matches at 100% with ours
Posts: 8 |
J'avais une fuite à u capteur. J ai mis un nouveau joint dans la rainure et un autre tout au fond et depuis plus de fuitef
Posts: 286 Likes: 3
Posts: 286 Likes: 3 |
I ran google translate as my French is not that good. Previous post says: "I had a sensor leak. I put a new seal in the groove and another at the bottom and since then no more leaks."
Merci, Patrick
2020 M3W
Posts: 2,142 Likes: 43
Posts: 2,142 Likes: 43 |
Fixing the leak is not so much of an issue as replacing the CPS when they are not available from S&S. Great info Bunny, the V-Rod one with a suitable spacer looks like the best alternative for now if you need one. As it works it's on the next Alternative Parts List update until we find something better.
Posts: 7,914 Likes: 243
Posts: 7,914 Likes: 243 |
Yes, you're right. It would be great to be able to rifle through their parts bins to find something that would fit. These two may be likely candidates? ![[Linked Image]](https://tm-img.com/images/2022/07/24/Screenshot-2022-07-24-at-19.54.15.png) ![[Linked Image]](https://tm-img.com/images/2022/07/24/Screenshot-2022-07-24-at-19.46.34.png) Andy, looks like you need to find a friendly 3.0L series 1 Roadster owner and compare what he has
Posts: 1 |
![[Linked Image]](https://www.tm-img.com/images/2022/08/14/Screenshot-2022-08-14-at-18.29.30.md.png) Looks close, but my investigations so far have found that if it's not right, it's not right! Also, it doesn't have an o-ring around the shaft so would probably leak. Nippymog & I are currently working on an adapter kit that will allow the Harley V-Rod sensor to be used. Watch this space!
Andy
Posts: 756 Likes: 9
Posts: 756 Likes: 9 |
I found a sensor catalog that gives the impedance of the inductive sensor the length without the diameter, I'll look at the impedance of my backup sensor. http://www.fae.es/fr/produits/capteur-regime-et-positions
