2 members (jbk, Vansrv6), 460 guests, and 41 robots.
+8Rich 69
Adam12 69
John V6 52
9,215 Registered Users
Folding Reclining Seat Knob
Goodwood Speedmog 2d august
by Nick55 - 01/08/25 09:09 PM
Walnut Dashboard
by +8Rich - 01/08/25 06:24 PM
SORN
New
Morgan plus Four 2025
by Jérôme, August 2
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
Topics48,375
Posts813,542
Members9,215
Page 4 of 9 1 2 3 4 5 6 7 8 9
Bunny Offline OP
Originally Posted by Marmota
This page / manufacturer is quite intersting: DORMAN https://www.dormanproducts.com/gsea...igin=keyword&q=crank+position+sensor They're American (as S&S) and they offer a bunch of crank position sensors... the choices are so many, that I'm convinced there should be one amongst all these that matches our needs.
Yes, you're right. It would be great to be able to rifle through their parts bins to find something that would fit. These two may be likely candidates?
Andy
Could this firm be of any help ?
Maybe worth sending them a duff one as a pattern.
2009 4/4 Henrietta
1993 Connaught Green +8 prev
Looks terrific too! Plenty of choices! But same complaint: they don't put the dimensions of their sensors in the web page, so it's a total gamble to find the one that matches at 100% with ours banghead
www.speedymarmots.com
J'avais une fuite à u capteur. J ai mis un nouveau joint dans la rainure et un autre tout au fond et depuis plus de fuitef
I ran google translate as my French is not that good. Previous post says:
"I had a sensor leak. I put a new seal in the groove and another at the bottom and since then no more leaks."
Merci, Patrick
2020 M3W
Fixing the leak is not so much of an issue as replacing the CPS when they are not available from S&S. Great info Bunny, the V-Rod one with a suitable spacer looks like the best alternative for now if you need one. As it works it's on the next Alternative Parts List update until we find something better.
Andy, looks like you need to find a friendly 3.0L series 1 Roadster owner and compare what he has
Bunny Offline OP
Looks close, but my investigations so far have found that if it's not right, it's not right! Also, it doesn't have an o-ring around the shaft so would probably leak.
Nippymog & I are currently working on an adapter kit that will allow the Harley V-Rod sensor to be used. Watch this space!
Andy
I found a sensor catalog that gives the impedance of the inductive sensor the length without the diameter, I'll look at the impedance of my backup sensor.
http://www.fae.es/fr/produits/capteur-regime-et-positions
