4 members (Morganmike, Luddite, RibbleAdventures, Hamwich), 338 guests, and 32 robots.
Adam12 69
+8Rich 67
John V6 60
9,215 Registered Users
SORN
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,367
Posts813,407
Members9,215
Rbt Aero8, Salmon, stevends
Page 5 of 7 1 2 3 4 5 6 7
Laurens #748685 19/07/22 05:20 PM
I forgot to say that I made myself a thicker nut that comes just at the end of the crankshaft thread because the original one seems weak to me.
Laurens #748692 19/07/22 06:11 PM
I know what you mean Chris (and Laurens) but locking the nut via the star washer to a moveable plain washer doesn't seem to be locking at all to me. I do like the idea of the dose of Loctite 660, at least until it needs to be taken apart...but if it all works as it should that hopefully won't be your problem.
Laurens #748695 19/07/22 06:48 PM
I would say that what stops the hub from rotating on the splines even minutely is the friction between the end of the hub and the crank bearing journal
That is created by the nut being tightened to the correct torque of course
it seems to me that the plain washer is critical in transmitting that force through from the nut to the hub end as it is a bigger diameter and much thicker than the locking washer alone.
PaulR
Chris99 #748698 19/07/22 06:59 PM
Originally Posted by Chris99
Originally Posted by PeterG
I know PB doesn't like threadlock etc,
I've just re-watched Phil's video and although he doesn't show it he does say that for his final assembly of the splined flange onto the crankshaft he used Loctite and a washer.
Quite correct Chris. Phil does use it. I'll shut up hide
PeterG #748703 19/07/22 07:50 PM
Please don't shut up Peter, the more ideas and input the better thumbs
Red Leader drive
PaulR #748704 19/07/22 07:52 PM
To me that makes sense. Is there room for a larger diameter flat washer to spread the load even more?
Also would it make sense to use two half nuts rather than one full size so one acts as a locknut?
Red Leader drive
PaulR #748750 20/07/22 09:11 AM
mph Offline
If that were the case you wouldn't need splines. A secured splined coupling that is required to transmit loads in both directions is not ideal. A tapered or keyed coupling should have been used.
If it were the tension created by the nut that prevented rotational movement a spline wouldn't be necessary and a plain shaft with the coupling loosely slipped over would suffice. Clearly this wouldn't work.
It's likely that however tight the nut is there will be relative movement of the coupling on the splines. The only practical solution is to lock the nut in place. There are numerous means of doing this and proprietary locking devices available.
Laurens #748758 20/07/22 10:25 AM
Would it be possible to use tab washer?
Don't know-just a thought
mph #748804 20/07/22 04:33 PM
^It's likely that however tight the nut is there will be relative movement of the coupling on the splines^
I wonder why then the nut hasnt come loose on the majority of cars?
PaulR
PaulR #748813 20/07/22 05:15 PM
Laurens Offline OP
Original rubber rollers, flat washer, star washer and half a nut ?
www.m3w-jungfrau-treffen.com
