Topics48,364
Posts813,342
Members9,215
Posts: 51 |
I Havea 1964 Plus 4 and want to replace the clutch.
Where can I find step by step instructions?
Thank you
Posts: 32 Likes: 4
Posts: 32 Likes: 4 |
Could try Haynes manual for Triumph tr on eBay
Posts: 28,428 Likes: 180
Posts: 28,428 Likes: 180 |
Morgan Four Owners Workshop Manual 1936-1981 Brooklands Books OWM796
Sold L44FOR 4/4 Giallo Fly '09 Gen2 MINI Cooper ragtop '90 LR 90 SW
Posts: 26,760 Likes: 425
Posts: 26,760 Likes: 425 |
Posts: 1,578 Likes: 105
Posts: 1,578 Likes: 105 |
Could try Haynes manual for Triumph tr on eBay Doubt it! Absolutely NO Morgan/Moss Gearbox content in a TR4 Haynes manual. Arwyn
Posts: 55 |
As I remember....
Seats out transmission tunnel out gearbox out jackshaft housing and shaft out
replace clutch
replace all else in reverse order, checking the release brg sleeve and carbon. The carbon pad used to be replaceable. miserable job. Also check slot in bottom of jackshaft housing for wear caused by the carbon pad carrier pin.
or..and we made a special tool to do this....we could lift the engine up and do the clutch from the engine side but required the special homemade tool to centre the clutch disc. I think the last one I did was circa 1971-2
1963 4/4 SER.V. B876 Owned since 1968 -1965 Anglia 124E- sold.
Posts: 116 Likes: 2
Posts: 116 Likes: 2 |
I seem to remember that a cut-down pilot shaft makes the best alignment tool.
Posts: 55 |
The issue is when taking out the engine it won't come out with the clutch bolted to the flywheel. Taking off the fan and w/pump and crank pulley gives just enough room to unbolt the clutch and push the clutch back into the bellhousing and remove the engine in order to extract the clutch.
Either way, it's a lot of work.
I seem to remember that a cut-down pilot shaft makes the best alignment tool. Never needed one, always been able to set them up by eye. If you need one for a Moss box car, let's just say there's an alignment tool already there! Arwyn
