4 members (Jo S, PeterVD, RichardV6, BobtheTrain), 257 guests, and 28 robots.
John V6 69
DaveW 68
+8Rich 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Topics48,343
Posts813,023
RedThree
#754435 04/09/22 12:48 PM
PaulM3W Offline OP
Hi all, for those of you who have the tacky plastic rear view mirror that came with some Morgan's and was supported by the little device seen in the first photo, the second image shows a very nice replacement option which has mounting holes exactly the same distance apart as the Morgan original.
[img]https://tm-img.com/image/zL3pO[/img]
[img]https://tm-img.com/image/zLFb3[/img]
I bolted mine on today, very happy. No affiliation, just wish Morgan hadn't been so cheap arse with the shitty stock mirror.
At 127mm it completely clears both windscreens. Note that there is a bigger version which would probably be too wide.
M3W 2017 Sport blue.
PaulM3W Offline OP
Nice mirror. Luckily the later cars didn't come with this. Thanks for posting. I presume that the stem is stiff enough that it isn't misaligned by the wind at speed?
Craig - Texas, USA
2021 M3W
PaulM3W Offline OP
Yes, in fact it vibrates less than the side mirrors. There is a screw adjacent to the ball joint which I suspect is to tighten said joint should it become loose over time.
Your side mirrors vibrate? I don't have that problem. But I have noticed that I am always followed by a 9.2 magnitude earthquake that causes the entire world behind my to shake violently. I figured this was simply because of my awesomeness! smile
Nice to know about the adjustment screw. I have considered if this would be a nice upgrade. I like that it comes with earthquake compensation technology.
Craig - Texas, USA
2021 M3W
PaulM3W Offline OP
I am pretty awesome too!!!! Could explain a few things lol.
Hi Mr Awesome
Could you share a picture of the completed installation as I have been considering a centre mount rear veiw mirror. Thanks
Malcolm (probably not as awesome as you guys!)
PaulM3W Offline OP
Lol, here you go MalcolmM3W.
Just the right amount of clearance for the standard windscreens. Don't mind the marks, just the remains of some dead bugs from the test drive. (3 hours in the hills)
Love it....
Seems like a man really enjoying his car
I've been using one of those on the old F Super and over 10 years of vibration testing it's held together very well
