Posts837,267
Posts: 1,575 Likes: 55
Posts: 1,575 Likes: 55 |
![[Linked Image]](https://www.tm-img.com/images/2020/02/11/socket.md.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/02/11/socket2.md.jpg) This is available from scparts.co.uk, 01293 847200 It's listed as 'Special tool' for 42mm octagonal spinners, 3/4" drive, part no. 479748. Cost is £48 inc vat ( same as 2018) This has 3 great advantages. No dented wings, ditto wheel rims. The best bit is you can use a torque wrench. I started with 60ftlbs and marked the spinners against a marked spoke. I found only one of the self tightening spinners moved (tighter). At 80ftlbs there has been no movement at all. Why beat the sh*t out of your spinners with a hammer to silly ftlbs when you can easily set them all at a modest torque value and easily get them undone again without the need of a 10 foot spanner?  I know some one will have been using a hammer for 80 years without a problem but we can all have an off day! No finantial interest and no hammer. This looks promising. What length of lever are you using?
Morgan Plus 4 Royal Enfield Classic 350 Brompton M6L Giant TCX Advanced
Posts: 5,586 Likes: 603
Posts: 5,586 Likes: 603 |
Just mentioning that you can do an awful lot of butchery with a six foot cheater bar ... good quality steel twisting like cheese ...I know this from sad experience (though not on the Morgan fortunately) 🙂
I wouldn't go overboard with the leverage!
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Agreed.i have a 750mm bar to tighten.
Posts: 309 Likes: 9
Posts: 309 Likes: 9 |
![[Linked Image]](https://www.tm-img.com/images/2020/02/11/socket.md.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/02/11/socket2.md.jpg) This is available from scparts.co.uk, 01293 847200 It's listed as 'Special tool' for 42mm octagonal spinners, 3/4" drive, part no. 479748. Cost is £48 inc vat ( same as 2018) This has 3 great advantages. No dented wings, ditto wheel rims. The best bit is you can use a torque wrench. I started with 60ftlbs and marked the spinners against a marked spoke. I found only one of the self tightening spinners moved (tighter). At 80ftlbs there has been no movement at all. Why beat the sh*t out of your spinners with a hammer to silly ftlbs when you can easily set them all at a modest torque value and easily get them undone again without the need of a 10 foot spanner?  I know some one will have been using a hammer for 80 years without a problem but we can all have an off day! No finantial interest and no hammer. This looks promising. What length of lever are you using? To undo I use a standard breaker bar and to do up I use a standard torque wrench set to 80ftlbs. Simples!
1994 +8, BMW Calypso Red. 2002 4/4, 4 seater, BMW Calypso Red. How do you open the boot?
Posts: 40 |
ive made an adaptor like yours but my torque wrench only goes up to 70 ftlbs is there a factory setting that you know off ?
Posts: 8,655 Likes: 407
Posts: 8,655 Likes: 407 |
Agreed.i have a 750mm bar to tighten. Ditto and I would suggest the max length you use with a small grunt to tighten. The MG style two ear spinner removal tool I carry in the car is shorter but with the drama of an unscheduled wheel change plus a couple of extra grunts, is just adequate to remove if previously tightened as above. Having said that 80 lbft sounds too low for a spinner and closer to what I would expect for each of the five nuts on a flange wheel hub.
Posts: 128 Likes: 3
Posts: 128 Likes: 3 |
Aren't spinners self tightening? So you just nip them up and epicycling action does the rest.
Posts: 309 Likes: 9
Aren't spinners self tightening? So you just nip them up and epicycling action does the rest. Yes, you're right, although torqued to 80ftlbs I have found no movement of the centre nut either way.
Aren't spinners self tightening? So you just nip them up and epicycling action does the rest. Yes but there are two schools of thought. One is to tigthen loosely the is to tighten hard.
Posts: 1,242 Likes: 30
Posts: 1,242 Likes: 30 |
After owning my 4/4 for 11 years, I have given up trying to get a torque setting for the wires. Depends on where you look. Old timers tools or JaguarI just nip them up. After a while I need a rather long breaker bar to get them undone.
