3 members (RubyMog95, RichardV6, Viper), 358 guests, and 53 robots.
+8Rich 90
Topics49,841
Posts837,320
Page 3 of 3 1 2 3
Originally Posted by sospan
It begs the question of how the dealers lift the cars using their commercial lifts if a Morgan chassis is so “ fragile”.
The Holden scissor lift is tempting me and the videos on their website show it in action.
If I jack up my Morgan it is always front or back, never one corner. Never had to use the small jack to change a wheel yet either.
Jacking beam for the rear and central on the Crosshead at the front. Axle stands at recommended points where triangulation points of crossmembers/ chassis parts coincide
The Holden Lift is the EZ Car Lift, you purchase the correct crossbeam so it fits the full frame of the chassis and lifts the car as one so the whole chassis is effectively supported. At the end of the day the Morgan is a light weight vehicle and the chassis is quite strong, look at the ones that have survived crashes, would take a lot more than lifting one up to cause damage, I've never heard of a Morgan chassis being weakened or damaged by lifting!!!!
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Rog Offline
Originally Posted by CBY
In 2015 I made finite element modelling on a 2005 PLUS 4 chassis making assumptions on the weight distribution but checking that I got the same measured weight on the wheels than during the MOT.
It could give an idea of the structural deformation and stress in the chassis and particulary in the girder which is a critical element.
For example when you lift the car under the first cross member ( see picture :point de levage) the maximum constraint is 4.84 daN/mm².
The maximum is 6,26 daN/mm² (von Mises constraint) when you lift the car by the rear croos member.
Minimum is on front cross frame (3,11 daN/mm²).
I don't know what steel is used by Morgan, but with a 36 daN/mm² elasticity limit steel you get a safety coefficient of 6.
You can use any cross member without stressing the chassis, some are better than other.
Hey CBY that’s a nice bit of analysis thumbs And thanks for the reassurance that the dealer most likely hasn't bent my car smile
The power of modern FEA is impresive, how on earth did we ever manage in the olden days!
Roger
These are the only two places I jack the car from, so take it I’m lifting in the correct places ?
I haven’t attempted lifting the car from any other points of the chassis. Looks like you could easily get it wrong.
Craig Jezz
Page 3 of 3 1 2 3
