2 members (JoeSpeetjens, Beard),
243
97
Topics49,847
Posts837,389
Posts: 4,612 Likes: 15
Posts: 4,612 Likes: 15 |
I was warned by Richard Thorne that you may get slight movement with any attachment to the wing as apposed to being attached to a bumper support.
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
I was warned by Richard Thorne that you may get slight movement with any attachment to the wing as apposed to being attached to a bumper support. Agreed, that's a fair bit of weight jiggling around on a bracket bolted to thin aluminium, I made brackets that fitted to the main chassis to bumper bolts which were much more stable on todays potholes roads
Posts: 58 Likes: 2
Posts: 58 Likes: 2 |
I also made stainless steel L shaped brackets to fit on the bumper mounts. I actually had 5 sets made in case anyone wanted a pair. I haven’t a clue how to add a picture. Sorry B
Morgan Roadster S2 Jaguar F Pace S WW2 Jeep
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
I was warned by Richard Thorne that you may get slight movement with any attachment to the wing as apposed to being attached to a bumper support. Agreed, that's a fair bit of weight jiggling around on a bracket bolted to thin aluminium, I made brackets that fitted to the main chassis to bumper bolts which were much more stable on todays potholes roads Dam, that’s now put me off having spot lights
Craig Jezz
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
I have Cibie Oscars mounted with those Wipac brackets. No problems.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
I’ve got foglights mounted with brackets onto the wings. Apparently from new 22 years ago. No problems with wing damage. Never had to touch them as always stable. No loosening of bolts.
Posts: 1,444 Likes: 9
Posts: 1,444 Likes: 9 |
I was warned by Richard Thorne that you may get slight movement with any attachment to the wing as apposed to being attached to a bumper support. I had pretty much the same comment from Richard Thorne. For this reason I decided not to fit spotlights as it sounds potentially problematic. But plenty of cars have them so there must be a way to do it.
David 2020 Roadster 3.7 Dove Grey.
Posts: 5,439 Likes: 131
Black Rat Charter Member
Posts: 5,439 Likes: 131 |
Instead of fog/spot lights I fitted replacement LED headlight units, no need for extra lights now.
Posts: 145 Likes: 1
Posts: 145 Likes: 1 |
Couple of cibies spots mounted on the bumper mountings,you can see for f***ing miles. the morgan fog lamps it makes very little difference to the vision at night or in the fog. I have a couple of morgan lamps under my bench if anyone wants them.
IMHO Chris + 8 's
