1 members (Graham, G4FUJ),
304
38
Topics48,355
Posts813,245
Members9,215
Posts: 4,607 Likes: 14
Posts: 4,607 Likes: 14 |
I was warned by Richard Thorne that you may get slight movement with any attachment to the wing as apposed to being attached to a bumper support.
Posts: 7,908 Likes: 241
Posts: 7,908 Likes: 241 |
I was warned by Richard Thorne that you may get slight movement with any attachment to the wing as apposed to being attached to a bumper support. Agreed, that's a fair bit of weight jiggling around on a bracket bolted to thin aluminium, I made brackets that fitted to the main chassis to bumper bolts which were much more stable on todays potholes roads
Posts: 57 Likes: 2
Posts: 57 Likes: 2 |
I also made stainless steel L shaped brackets to fit on the bumper mounts. I actually had 5 sets made in case anyone wanted a pair. I haven’t a clue how to add a picture. Sorry B
Morgan Roadster S2 Jaguar F Pace S WW2 Jeep
Posts: 2,222 Likes: 20
Posts: 2,222 Likes: 20 |
I was warned by Richard Thorne that you may get slight movement with any attachment to the wing as apposed to being attached to a bumper support. Agreed, that's a fair bit of weight jiggling around on a bracket bolted to thin aluminium, I made brackets that fitted to the main chassis to bumper bolts which were much more stable on todays potholes roads Dam, that’s now put me off having spot lights
Craig Jezz
Posts: 2,396 Likes: 14
Posts: 2,396 Likes: 14 |
I have Cibie Oscars mounted with those Wipac brackets. No problems.
1969 4/4 1995 plus 8 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 9,285 Likes: 69
Posts: 9,285 Likes: 69 |
I’ve got foglights mounted with brackets onto the wings. Apparently from new 22 years ago. No problems with wing damage. Never had to touch them as always stable. No loosening of bolts.
Posts: 1,440 Likes: 8
Posts: 1,440 Likes: 8 |
I was warned by Richard Thorne that you may get slight movement with any attachment to the wing as apposed to being attached to a bumper support. I had pretty much the same comment from Richard Thorne. For this reason I decided not to fit spotlights as it sounds potentially problematic. But plenty of cars have them so there must be a way to do it.
David 2020 Roadster 3.7 Dove Grey.
Posts: 5,109 Likes: 56
Black Rat Charter Member
Posts: 5,109 Likes: 56 |
Instead of fog/spot lights I fitted replacement LED headlight units, no need for extra lights now.
Posts: 143 Likes: 1
Posts: 143 Likes: 1 |
Couple of cibies spots mounted on the bumper mountings,you can see for f***ing miles. the morgan fog lamps it makes very little difference to the vision at night or in the fog. I have a couple of morgan lamps under my bench if anyone wants them.
IMHO Chris + 8 's
