6 members (Graham, G4FUJ, Ritchie B, RichardV6, Socalm3w, Happy super 3, flyfisher),
247
59
Topics49,863
Posts837,547
Posts: 159 |
I recently ordered a new set of seatbelts from Morgan Spares and I'm just a tad nervous as they are a little different to what is currently there . The current reel anchor point has two locations to bolt the reel housing - on the top and from the side whilst the new one only has a bolt hole on the top. I was wondering what other Morgans of this age tended to have for their anchor points and whether it's considered safe to install the new ones. The current installation with a large wood screen through the side anchor plate doesn't look particularly well done, so perhaps this was an after market addition . Pictures can be found here - thanks you. Original : Original reel with top and side anchor pointsNew : New seatbelt with single anchor pointSide view : showing wood screw position for second anchor point
1974 4/4 2 seater
Posts: 3,697 Likes: 131
Posts: 3,697 Likes: 131 |
The current installation with a large wood screen through the side anchor plate doesn't look particularly well done, so perhaps this was an after market addition . I'm fairly sure a 1974 4/4 wouldn't have had inertia reel belts originally, my 1980 model doesn't have them.
Posts: 28,900 Likes: 352
Posts: 28,900 Likes: 352 |
My '76 2 seater didn't either.
Posts: 5,465 Likes: 171
Posts: 5,465 Likes: 171 |
Our previous, 1985, 4/4 had static belts when we viewed it. Mike & Ben Duncan fitted inertia reel belts as part of the deal when we bought the car from them.
Posts: 159 |
Oh bummer, I should have checked and gone with the original - Graham and Ian - did your cars just have a lap belt or a 3 point with a single anchor point on the wheel arch ?
1974 4/4 2 seater
3 point Rob  It is possible to retrofit inertia reel, not that I bothered.
Posts: 172 |
Our 1985 4/4 came from the factory with static belts, I recently fitted inertia reel belts. All of the fixings were the standard 7/16 UNF seatbelt thread into captive nuts. The original fixing through the top of the wooden wheel arch on our car is a 3/4" thread nut and bolt drilled & tapped 7/16 UNF for a standard seat belt bolt. I found that the new seat belt buckles needed silicon spray ("Mr. Sheen" in the UK) to make them release easily.
Jack 1985 4/4 T/C 4 seater Royal Ivory 1934 F Type 2018 Pembleton SuperSport (self built).
Posts: 5 Likes: 1
Posts: 5 Likes: 1 |
My 2019 Plus 4 needs replacement belts which is disappointing given age and low mileage. Any suggestions as to where these can be sourced apart from MMC or Morgan dealers? Thanks.
Cheers, Philip 2019 Morgan Plus 4 BRG Mercedes SL400 (prev)
Posts: 1,616 Likes: 142
Posts: 1,616 Likes: 142 |
Try: https://www.quickfitsbs.com/They can rebuild your existing seat belts or supply new ones. Arwyn
Posts: 8,678 Likes: 491
Posts: 8,678 Likes: 491 |
Arwyn's contact have a good reputation
A few Mog owners have used these too, FDTS Seatbelts - tel 01932 342043
