10 members (+8Rich, High Hamster, MartO, jbk, RubyMog95, JohnHarris, James B W, RichardV6, Peter G3VNH, sezznowt),
311
106
Topics49,869
Posts837,664
Posts: 103 |
I’m wanting to swap out the standard brake bleed nipples for stainless alternatives. I can’t find any off the shelf kits only singles and pairs. Issue is that I need to know the size (I know I could measure them but I’d like to order in advanced). I know the early ones are 3/8 at the front but I’ve no info on the rears also would they have switched to metric by 1994 (plus 4). Grateful for any help on sizes or kits
Thanks
Tony
1994 Connaught Green Plus 4
Posts: 1,245 Likes: 30
Posts: 1,245 Likes: 30 |
I've just done exactly that for the front, Caparo callipers on my 2011 4/4 I found some titanium ones from Nipple part TBNM101BR, seems to fit. Good luck. Please let us know if you find any for the rear cylinders.
Posts: 8,684 Likes: 493
Posts: 8,684 Likes: 493 |
I can't find my 'don't mix metals' chart, but I always thought mild steel (cast iron) and threaded stainless shouldn't be mixed ?
Posts: 2,093 Likes: 74
Posts: 2,093 Likes: 74 |
I can't find my 'don't mix metals' chart, but I always thought mild steel (cast iron) and threaded stainless shouldn't be mixed ? Yes, although galvanic corrosion can take place between cast iron and stainless steel, the fact that the stainless part is so much smaller than the iron part and contact interface is so minimal, then in practice it is unlikely to cause a problem. (Note: I am not a metallurgist, just a googler!)
Posts: 161 |
- Nelson
1966 Plus 4 RHD
Posts: 6,671 Likes: 438
Posts: 6,671 Likes: 438 |
Also available this side of the pond Goodridge Speed Bleed
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
Not sure there is any benefit in changing them to stainless steel.
A dab of copper grease on the threads of the mild steel ones is sufficient to stop them seizing up.
Also there are some very badly machined ones out there which don't seal up properly
Arwyn
Posts: 267 Likes: 2
Posts: 267 Likes: 2 |
I agree with Arwyn 100%. There is no benefit and it could cause problems down the line.
Posts: 103 |
Thanks all. Copper grease on order!
Tony
Posts: 150 |
Don’t mix stainless with alloy, you’ll get corrosion or seizure
