Topics49,868
Posts837,639
Posts: 102 Likes: 1
Posts: 102 Likes: 1 |
So for some months now my Plus 4 has produced a Rubbing sound when cornering right. I have looked at all sorts of things trying to find the cause, or even evidence of something to no avail. Even had the front nearside wheel bearing changed! Well this week I jacked up the front as far as I could and put it on axel stands, crawled underneath and eventually spotted that near the rear of the gear box approx underneath the gear shift there is a bracket to support the back of gearbox before the UJ and the two bolts were missing. When cornering the whole engine & gear box would move sideways! One bolt was stil lying in the bracket after 100s of miles so that has gone back in with some loctight the other I will have to replace but it is in a p#g of place you cant get at. ![[Linked Image]](https://www.tm-img.com/images/2022/11/02/20221102_151611.jpg) ![[Linked Image]](https://www.tm-img.com/images/2022/11/02/20221102_151543.jpg) Now onto that really anoying woodpecker tapping noise......
Tim Plus 4 2018
Posts: 8,683 Likes: 413
Posts: 8,683 Likes: 413 |
Well spotted and quite scary. Lucky there was no damage. Good luck fitting that second gearbox bolt.
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
Posts: 28,902 Likes: 352
Posts: 28,902 Likes: 352 |
Good find!
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
I appreciate it is some extra work but it might be easier to take out the seats and the transmission tunnel and work from inside the car?
Posts: 586 Likes: 21
Posts: 586 Likes: 21 |
I appreciate it is some extra work but it might be easier to take out the seats and the transmission tunnel and work from inside the car? A good point, especially if you're going to change the gearbox oil at the same time, and get at that grease nipple. Also an opportunity to deep clean the underseat carpets/area, and treat the woodwork if your minded.
"DOT" 35th Anniversary Edition Plus 8- family owned from new. Rolls Royce Pewter. 06 Saab 93
Or as you can see into the tunnel then cut an access hole
Posts: 8,682 Likes: 493
Posts: 8,682 Likes: 493 |
So for some months now my Plus 4 has produced a Rubbing sound when cornering right. I have looked at all sorts of things trying to find the cause, or even evidence of something to no avail. Even had the front nearside wheel bearing changed! Well this week I jacked up the front as far as I could and put it on axel stands, crawled underneath and eventually spotted that near the rear of the gear box approx underneath the gear shift there is a bracket to support the back of gearbox before the UJ and the two bolts were missing. When cornering the whole engine & gear box would move sideways! One bolt was stil lying in the bracket after 100s of miles so that has gone back in with some loctight the other I will have to replace but it is in a p#g of place you cant get at. ![[Linked Image]](https://www.tm-img.com/images/2022/11/02/20221102_151611.jpg) . No witness marks that there's ever been a bolt fitted to that, which is a bit worrying... As access is tight, you could try threading a bolt or length of studding from above & than lock off with a nut below perhaps
When all nipped up it might be worth checking engine mounts Tim. There would have been considerable leverage on them from loose gearbox.
