0 members (),
240
57
Topics49,844
Posts837,360
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
If anyone is experiencing a stiff rotary heater control knob, mine has been really hard to turn lately on my 2016. 4/4 Sport. So stiff had to use two hands before setting off today. So this afternoon on my return, I decided to drop the under tray and dashboard to see what’s going on. I could see the bolt going through the two plates controlling the heater control knob was quite tight. I loosened the locking nut right off and sprayed WD40 silicone until it worked free again, applied a little grease and tightened back up, but not so tight this time. job done. So if anyone else has the same problem turning the heater it’s any easy fix if I can do it. ![[Linked Image]](https://tm-img.com/images/2023/01/15/BAAC83AD-69B5-4873-A6DD-FFAB67E1890B.jpeg) ![[Linked Image]](https://tm-img.com/images/2023/01/15/9DD08FCC-6AB5-4D23-ADD1-551A5472B72B.jpeg)
Craig Jezz
Posts: 1,615 Likes: 1
Posts: 1,615 Likes: 1 |
SFG 2012 4/4 Sport
Posts: 901 |
Thanks Craig. I will have a look at mine when the weather gets a bit better!
Rob
Posts: 8,664 Likes: 408
Posts: 8,664 Likes: 408 |
Good fix Craig  Just be aware that loosening the pivot bolt may allow the detent ball to escape as that is sandwiched between the two plates. This assumes there is a detent there in the first place. My car has never had one.
Good fix Craig  Just be aware that loosening the pivot bolt may allow the detent ball to escape as that is sandwiched between the two plates. This assumes there is a detent there in the first place. My car has never had one. Thanks for that information Richard, i wasn't aware of that.
Craig Jezz
Posts: 81 Likes: 1
Posts: 81 Likes: 1 |
Kevin Davies
Posts: 22,357 Likes: 353
Posts: 22,357 Likes: 353 |
Question for Craig. In the first picture, there is a black wire leading down into a long slot shielded by a metal cover. What is this?
I'm asking because my GDI has the slot cut in the panel, but no wire or metal cover.
I'm asking because my GDI has the slot cut in the panel, but no wire or metal cover. Hi Dave, the wire goes to the LED foot-well lighting.
Craig Jezz
Ahhhhh! Thanks.
Posts: 2,125 Likes: 37
Posts: 2,125 Likes: 37 |
Ahhhhh! Thanks.  You mean you don't have footwell lighting, Dave??
Regards Alan AP08 MOG 2016 Plus 4 GDi - Mazda Soul Red Metallic
