10 members (Arwyn Williams, John Wilcox, AlyMatt, Plus Four Guy, jbk, Sir Percival, TalkMorgan, JohnHarris, Saxman1964, gomog),
218
35
Topics49,901
Posts838,046
Posts: 1,562 |
Are we saying categorically the M3W bevel box does not have a hunting tooth ( or something similar) ratio in its gears ?
Posts: 786 Likes: 18
Posts: 786 Likes: 18 |
Thank you RICHARD V6 for supplementing information, moreover in the m3w 5 speed there were two types of teeth 1/2 the first model of teeth was much more inclined (2012) because in 2013 the teeth were larger and less inclined and machining a bit rude. It also seems to me that the crown gear pinion ratio for the belt transmission is 1/2 corrected by the number of teeth of the belt.
In life there are more engineers than ingenious.
Posts: 8,697 Likes: 416
Posts: 8,697 Likes: 416 |
If you know the specific number of teeth on CW & P you can check yourself given link I posted. Sorry but forgotten now what mine were. First came across this engineering solution during a discussion on a Velocette I owned. The gears in drive to magneto were chosen to provide hunting tooth on later models. In this case it was particularly relevant as points of max load on driven device would otherwise relate to the same engaged teeth.
Posts: 120 Likes: 1
Posts: 120 Likes: 1 |
I had the belt drive adjusted today. The squealing noise has now gone under all levels of load. The belt was out of alignment which caused the noise. Hopefully this will be useful for people who have the same noise on their Super 3s. Hi Barkbark - happy to hear that this has been resolved. Useful to know for other owners.
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
Ah thanks - makes sense. Indeed agree with JMD - what were Quaife thinking?
Posts: 100 Likes: 2
Posts: 100 Likes: 2 |
I had the belt drive adjusted today. The squealing noise has now gone under all levels of load. The belt was out of alignment which caused the noise. Hopefully this will be useful for people who have the same noise on their Super 3s. Great news! Did it need to be done by your dealership/factory? Is it something I can check myself or ask my mechanic to do for me?
Posts: 1,075 |
GLLOQ, I've sent you a PM, thanks!
Dan
Dan
Posts: 137 Likes: 1
Posts: 137 Likes: 1 |
I had the belt drive adjusted today. The squealing noise has now gone under all levels of load. The belt was out of alignment which caused the noise. Hopefully this will be useful for people who have the same noise on their Super 3s. Great news! Did it need to be done by your dealership/factory? Is it something I can check myself or ask my mechanic to do for me? I purchased mine from Morgan Works at the Factory. The service department is at the same location as the Factory so whilst separate I guess has easy access to the people at the Factory as they are all part of the same complex and know each other / work with each other.
