Topics49,866
Posts837,595
Posts: 793 Likes: 144
Posts: 793 Likes: 144 |
Your solution looks very nice.
Personally, I am always afraid that aluminium loaded with weight will break due to vibrations.
I have only good experiences with aluminum, even with additional weight, on a Harley. And a Dyna without balance shaft has viberationen without end The weight of the mainly plastic horns is minimal and the cantilever bracket at 6mm thickness provides a strong support. Been fitted for 3 years including numerous high vibration/rpm track days without issue. Loctite thread locker was used on the horn support screws.
Chris
2015 Plus 4 Silverlake Blue (2014 3.7 Roadster Crystal Blue) (2012 4/4 Sport Black)
Posts: 8,678 Likes: 412
Posts: 8,678 Likes: 412 |
Mounted my twin horns well out of the way behind the radiator on a bracket gismo I fabricated from sheet aluminium and off cuts. ![[Linked Image]](https://tm-img.com/images/2022/07/18/IMG_3021.jpg) That's taking engineering to an art form Chris  Given your qualifications I'm sure a load and stress assessment was calculated in advance
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
Thank you all for the explanations ! I did not want to critisize someone or the work! Many years ago I prepared my bike for a longer trip through norway. I glued a remote control for my walkman with cable (30x60mm/complete weight about 100gr.) On a fitting 4mm aluminium plate. This was fitted to the handlebar of my CX500. At the second day the plate fell of! That is an experience I'll never forget.....
Posts: 5,587 Likes: 603
Posts: 5,587 Likes: 603 |
Bmgermany ... it would probably never have happened if Honda had got the cylinders on straight!! 🤣
Chris describes his bracket as 'aluminium sheet' .... I think 'aluminium plate' would be a better description ... that's pretty chunky stuff!!
K  Hmmm, I have sometimes said something similar to motorcyclists with American motorbikes
Posts: 27,814 Likes: 749
Posts: 27,814 Likes: 749 |
It wouldn't have lasted a day on my T140V Bonnie. That was a bone shaker.
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
It wouldn't have lasted a day on my T140V Bonnie. That was a bone shaker. Or on the Guzzi V11 I owned for a while. Mind you, it felt as though it could tow a small caravan. Bud 4/4 - Stanley
Bud 4/4 "Stanley"
T140 !! .... you mark my words young man ... no good at all will come from taking that nice Triumph parallel twin out over 500cc .... tears before bedtime! 🙂
