8 members (B3MOG, Scrambledsignals, t50, Ulfulf, TBM, JohnHarris, linklaw, brownbaker),
371
43
SORN
Topics48,376
Posts813,550
Members9,215
Posts: 678 Likes: 82
Posts: 678 Likes: 82 |
Or a 19mm plywood off cut - say 150 x 150
Chris
2015 Plus 4 Silverlake Blue (2014 3.7 Roadster Crystal Blue) (2012 4/4 Sport Black)
Posts: 5,237 Likes: 128
Posts: 5,237 Likes: 128 |
In our old 4/4 we once had a puncture on the A50 dual carriageway. Limped to a slip road and changed the wheel. Jacking on tarmac, the factory jack was perfectly adequate. No sign of toppling or slipping. In this instance, as it was a rear wheel, I jacked the car under the spring close to the rear axle so the lift required was minimal.
It was our wedding anniversary and by the time I had changed the wheel, we had lost interest in our planned run to Dovedale. Ended up in a nearby pub for lunch.
And these show the jack in question being used on the front in the pitstop challenge at Newmarket. This is the DonMog ladies team. ![[Linked Image]](https://tm-img.com/images/2023/03/14/IMG_3931.jpeg) ![[Linked Image]](https://tm-img.com/images/2023/03/14/IMG_3940.jpeg)
Posts: 199 Likes: 1
Posts: 199 Likes: 1 |
I always carry a can of that puncture repair stuff....not necessarily a permanent fix, but enough so you can maybe change the wheel in a safer place...
Richard S 1993 4/4 1966 VeloSolex
Posts: 19 |
Re that squirty puncture repair stuff, I always carry a can in my tin top, but is it ok to use on wire wheels ??
Posts: 5,113 Likes: 57
Black Rat Charter Member
Posts: 5,113 Likes: 57 |
Re that squirty puncture repair stuff, I always carry a can in my tin top, but is it ok to use on wire wheels ?? It will probably work but then you will likely need to have the rubber seal replaced at MWS.
Posts: 3,669 Likes: 43
Posts: 3,669 Likes: 43 |
Re that squirty puncture repair stuff, I always carry a can in my tin top, but is it ok to use on wire wheels ?? I imagine it depends on whether you are using innertubes...if you are, I can't see how it could work. I'm often wrong though.....
Re that squirty puncture repair stuff, I always carry a can in my tin top, but is it ok to use on wire wheels ?? I imagine it depends on whether you are using innertubes...if you are, I can't see how it could work. I'm often wrong though..... Modern W/W are tubeless and shouldn't be fitted with tubes.
