10 members (B3MOG, High Hamster, Soleng, TBM, Bitsobrits, KLASG, ch44, Morganmike, TalkMorgan, gaston), 278 guests, and 60 robots.
+8Rich 95
Posts837,266
#774993 17/04/23 01:39 PM
Does anyone know what the actual factory specification is for coolant for a 2005 Plus 4? Unbelievably it's not in the handbook and I'm not sure if it is an HOAT type or not.
Thanks.
2005 Plus 4
2020 Hyundai eKona
2020 Mitsubishi Outlander PHEV
Topline123 #775023 17/04/23 07:07 PM
What colour is the coolant currently in the engine?
A Mk3 Mondeo that runs the 1.8 and 2.0 litre Duratec engine should use O.A.T antifreeze (organic acid technology) which is usually a fluorescent pinky/orange colour.
I'd assume Morgan would use the correct Ford Super Plus Premium WSS-M97B44-D which is orange in colour, if they did then something from any manufacturer that confirms to WSS-M97B44-D spec will be fine, it doesnt need to be the Ford/Motorcraft brand.
Confusingly some companies like Comma dye their WSS-M97B44-D red rather than orange, so don't go by colour, always make sure it shows WSS-M97B44-D in the spec on the back of the container.
Topline123 #775024 17/04/23 07:09 PM
In my 2011 +4, 2 litre Duratec, I have used Motorcraft Superplus WSS-M97B44-D which conforms to the spec in my handbook. It is orange in colour and have mixed it 50/50.
Last edited by Deejay; 17/04/23 08:01 PM. Reason: amended spec from an error of suffix 1 to suffix D
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Montegue #775029 17/04/23 07:18 PM
The thing is, mine is a purple/blue colour and was last changed in mid 2021 before I bought the car from Borghi Morgan in Milan. All servicing was done by them (I have enquired with them and hope to get a positive answer).
2005 Plus 4
2020 Hyundai eKona
Topline123 #775032 17/04/23 07:29 PM
Check out this thread Topline. The Mannol coolant I linked to and have been using does conform to WSS-M97B44-D as well as very many others.
BTW I can recommend this inexpensive coolant refractometer for measuring the freezing point of your coolant in situ. It can also measure SG of battery electrolyte to give accurate indication of your batterys SOC.
RichardV6 #775045 18/04/23 07:32 AM
Thanks for that. I had a look at refractometers and test kits etc but none of them can tell me what type of antifreeze I have, just the concentration levels.
2005 Plus 4
2020 Hyundai eKona
Topline123 #775047 18/04/23 07:46 AM
Nevertheless I used my identical refractometer to measure the unknown OE coolant in my car and the fresh Mannol, and both indicated exactly -40°C freezing point (can't remember which scale I used). For that reason I didn't dilute the Mannol which was the recommendation anyway. Anyone diluting the same 50/50 would be well advised to check the freezing point afterwards unless using concentrated coolant with specific dilution and performance recommendations.
BTW this device showed that my Land Rover coolant had dropped to just -10°C protection due to frequent topping up with water needing me to add undiluted fresh coolant to increase protection.
Topline123 #775080 18/04/23 05:29 PM
I've heard back from Borghi Morgan (Romeo Ferraris) in Milan and the red Mannol AF12+ is definitely the one to go for. Thanks for the help.
2005 Plus 4
2020 Hyundai eKona
Topline123 #775213 20/04/23 11:38 AM
I would drain it all down and replace it with water less coolant from Evans. You have to use a Prep fluid first, this I believe can be used again on other engines. But once you use the Evans, it last the life time of the engine. It might be idea to repace the pipework if required. I have no connection with the company, just very happy with it. Look at https://evanscoolant.co.uk for more info.
Navy Dave
1976 Morgan 4/4
DaveK #775216 20/04/23 02:28 PM
And here’s a 30-page thread that started off with waterless coolant….
http://www.talkmorgan.com/ubbthreads.php/topics/335878/1
grin2
