7 members (Scrambledsignals, BobtheTrain, Brian Dearle, Lordofthewings, JD44, verysideways, jim109b),
253
43
Topics48,346
Posts813,060
Posts: 703 Likes: 70
Posts: 703 Likes: 70 |
What is this lever under the dashboard for? : ![[Linked Image]](https://zupimages.net/up/23/16/7dge.jpg)
Lille - North Of France
Sold : MTW 2012 / Mog 4-4 Sport 2010 / Mog Roadster V6 2008 Mog Super3 2024
Posts: 487 Likes: 26
Posts: 487 Likes: 26 |
I am taking a shot in the dark here but perhaps interment wiper control?
Posts: 7,924 Likes: 217
Posts: 7,924 Likes: 217 |
Again just a guess, but it looks similar to a retro fitted multi function remote control for a car radio. I adapted similar from a Sony radio to use on my yacht. You can see it in this image below right hand side of chart plotter. ![[Linked Image]](https://i.imgur.com/pCEqcQt.jpg)
the car is not equipped with a car radio. however, it has the metal headlight and wiper controls, not the original plastic.
I believe Morganpark in Germany offer these turned metal stalk switch conversions but are unable to include the OE wiper delay. I guess Perry was right and a part of the old wiper switch has been fitted below dash and wired back in to perform this function Nestor.
Posts: 777 Likes: 88
Posts: 777 Likes: 88 |
Cool, that's a really neat solution
Posts: 26,748 Likes: 419
Posts: 26,748 Likes: 419 |
Then it is the wiper intermittent control
Posts: 145 Likes: 2
Posts: 145 Likes: 2 |
C'est effectivement la commande de réglage du balayage intermittent des essuie glace. Tu dois avoir les leviers inox qui en sont dépourvus.
Happy Morgan +8 (2001) owner BMW 435i - X Drive Royal Enfield 500 EFI Royal Enfield 650 Interceptor
Posts: 6,057 Likes: 160
Posts: 6,057 Likes: 160 |
You could always replace with one of these and control everything from the stalk. . Smartscreen Wiper controlI have one fitted to my 1972 4/4 and it gives you numerous intermittent wiper settings. Flick the wiper on once, flick it again at the required interval and it then copies until you cancel. - anywhere between 3 and 30 seconds. I have the wash/wipe version - when I press the windscreen washer, the wipers give three strokes - modern Mogs have this, but not the older ones. I've actually fitted a windscreen wiper and washer control on my steering column to replace the two switches on the dash. as it was a right pain in the dark to hit the switches
1972 4/4 4 seater, 1981 MGB GT 1984 Harley Davidson Electra Glide, 1990 Kawasaki ZX10
I will not have the use of this lever for the moment, because I disassembled the wipers because I put the car in Aeroscreen Brooklands configuration : ![[Linked Image]](https://zupimages.net/up/23/16/v945.jpg)
