3 members (B3MOG, Ian Wegg, Sir Percival), 363 guests, and 39 robots.
+8Rich 101
John V6 63
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,914
Posts838,196
Georgetoad, woolfie
Page 52 of 165 1 2 50 51 52 53 54 164 165
Originally Posted by TBM
Looking at your picture could you rotate the clevis joint on the bar 90 degrees? Then you could just cut a blank out of a chunk of suitable steel. Fairly easy to fabricate with a grinder and drill.
Unfortunately it isn't than simple. The clevis joint needs to be in the same plane as the one at the other end of the rod.
1956 Plus 4 4 seater
I'm in the process of upgrading my 1955 Plus 4 to later 7HA type brakes
I'll have a pair of backplates for sale shortly with newly rebuilt wheel cylinders, adjusters and rear handbrake pull rods.
Will be selling as complete unit though, no splitting
Arwyn
Arwyn,
I'll bear that in mind.
You could try these, Paul the owner is very helpful
https://www.powertrackbrakes.co.uk/products.html
Unfortunately Paul is unable to help.
Yesterday, actually, I got the front valance from Wolf Performance temporarily in place. I'll bolt it in after a bit more adjustment today.
Following the MIL indication last Sunday, it was diagnosed to be faulty EGR unit. Had my local garage replace it and now fine. A pig to get at, as it is on the end of the cylinder head at the back. Car has done 47k miles.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Installed the new floorboards today using the T-nut method in Fred Sisson's Bedside Reader. I made a very shallow counterbore on the top so the T-nut is flush with the surface. Thanks, Fred!!
manufacture of an Alu Rear panel, Details Here : read
http://www.talkmorgan.com/ubbthreads.php/topics/777565#Post777565
Lille - France
Plus Four 2024
Rebuilt a 3HA rear axle.
Crack tested the half shafts and lapped the hubs onto the shaft.
Mocked up the 7HA/Austin A60 type rear brake backplates. Found a 3mm spacer was needed so cut one out of steel plate with the gas axe and mounted it on stub mandrel in the lathe (actually an old kingpin - necessity being the mother of invention).
Drilled the spacer and lined every thing up.
Then my mate Big Dave turned up with a steering coupling he needed modifying for his BMW rally car so did that.
Will start on the axle again in the morning!!
Arwyn
Cleaned and treated the leather ahead of Belle being used at #3 son's wedding next week
