I had to ask for the C spanners and was given no instructions. When I got home I phoned up about the instructions and was told they were on the Web. They are not. E mail to SSL and instructions sent as attachment to returned mail. SSL said that a laminated copy of the instructions are provided with each kit!
I have set up the suspension using the spanners, the near side is spot on but the offside keeps varying. Can only think that I have a sticky king pin. New King's pins fitted with suspension.
Yes I dropped on a trolley jack a few times.
This can be tricky but as I said earlier a median can be found, important that kingpins freshly greased though. If there is a gap try lifting that side very gently under kingpin then leaving go. If the gap has closed you're nearly there, if not screw down collar a tad more.
Has anyone else noticed the front suspension skip/stiffen on hard fast cornering? I guess it’s the increased pin to bush frictional drag from the imposed side loading.
Yes yesterday but it was a washboard surface that caused it I believe and certainly not the norm.
