8 members (hugo, Bishmog, Rog G, sewin, Sloany, DaveK, Nickplus4, linklaw), 290 guests, and 40 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,363
Posts813,333
Members9,215
Mkiss Offline OP
I am thinking of the tiny hood swivel pivots that might save my finger tips as well as the screen.
Do they work on a four seater as well?
Thanks in advance!
Miklos
1985 plus 4 four seater
1992 Peraves ecomobil
bicycles (pedersen to recumbent)
It's a different model for the four seater. I don't know who supplies them now.
Someone will hopefully.
TBM Offline
Jon Taylor used to make 4 seater ones, but stopped some years ago. He sent me over some sketches and I made myself a set. I don't use them much, as I tend to leave the hood off from about Feb to Nov, and then put it on permantly over winter.
The only time I do use them is when I'm putting the hood up when it's cold, making the Everflex hood really stiff.
TBM Offline
Here's the thread and pictures. I've adapted further as the thumbscrews stuck out too far and put pressure on the hood. I now have a pair of thin head allen bolts. and a small ratchet allen key spanner that I keep in the glove box. Takes a few seconds longer but no great odds.
Swivel Thread.
formerly known as Hugh Jorgan
I can only speak for the 2 seater version, they're extremely good. If the 4 seater version works half as well they've got to be worth having.
+1 the 2 seater versions are brilliant, should be OE on every Morgan. 'Can't comment on 4 seater version sorry...
1969 4/4
1995 plus 8
2002 Aero S1
2013 M3W
2014 Plus 8
They are a superb solution to Everflex hood fitting, unless the hood is warm and therefore a bit flexible. One helpful tip I have seen is keeping the hood warm before fitting. Easy at home but a hot water bottle has been suggested for travel. Never tried it. I have the swivel pivots ( 2 seater car).
If I think I might need the hood on a run/trip I fit the rear and fold the front part to cover the rear shelf area like a mini tonneau cover. It acts as a sort of easy up hood and saves time fitting. I use the clear windows as guides to fold the material.
I also have an Everflex tonneau cover that is tight to fit unless warm.
Another tip is to help remove the head restraints. I use car wax on the stems. That makes them slide easier. No more flying head restraints or danger of hitting my face if they are tight and need force to slide them out!
Miklos
I wouldn’t want to be without them.
Mike H
Bourgogne Franche Comté
Excuse my ignorance, but what are good swivel pivots for?
2004 Series 1 Roadster
Mkiss Offline OP
Thanks very much - so I will go for the four seater version.
So even more I wonder why they never came as factory equipment...
Maybe I`ll fit the hood more often as the trip will lead all the way to Goodwood...
Have not had the hood mounted for the last two years - drove a bit faster instead.
@ Leroy: the swivels lower the hood bars so you should be able to fix it much easier to the screen studs and put tension on it by lifting it with the swivels as a last step.
