8 members (High Hamster, BillHart, DJC, mph, MartinB60, Morganmike, DMC1904, Graham, G4FUJ),
278
43
Topics48,364
Posts813,337
Members9,215
Posts: 584 Likes: 21
Posts: 584 Likes: 21 |
"DOT" 35th Anniversary Edition Plus 8- family owned from new. Rolls Royce Pewter. 06 Saab 93
Posts: 5,110 Likes: 56
Black Rat Charter Member
Posts: 5,110 Likes: 56 |
i had a problem with gears difficult to change on an 1984 Alfa Spider, Redline sorted it.
Posts: 59 Likes: 3
Posts: 59 Likes: 3 |
Hi again
Eventually it turned out that a simple adjustment of the rod connecting the slave cylinder and the lever arm at the bell house, as well as another bleeding of the hydraulic system solved the problem. It is possible to extend the lenght of the rod by turning it and fasten it by the lock nut. I've extended the rod approx 5 mm and it works. It's now possible to engage 1st at stand still and also engage reverse without grinding. However, the slave cylinder rubber cover has almost disintegrated and a complete new slave cylinder assembly has been ordered and will be changed as soon as it arrives.
Thanks to all for your inputs.
Cheers
/Finn
Finn. 1973 Morgan +8. 1959 Austin Healey 3000 BN7 2-seater. 2009 Mazda MX-5 2.0 PRHT.
