8 members (Image, Paul F, Malcolm T, RichardV6, chanteclair, dogmog, MartinB60, DJ66), 262 guests, and 9 robots.
John V6 69
DaveW 67
+8Rich 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Topics48,343
Posts813,022
RedThree
Redline MT90, as discussed previously on this forum, appears to be a good choice that may improve your issues.
http://www.talkmorgan.com/ubbthreads.php/topics/534022/1
https://www.opieoils.co.uk/p-1020-red-line-mt90-75w-90-gl4-synthetic-manual-gear-oil.aspx
06 Saab 93
Black Rat
Black Rat
i had a problem with gears difficult to change on an 1984 Alfa Spider, Redline sorted it.
Keith
2013 narrow bodied + 4 Ruby.
Sensei Offline OP
Hi again
Eventually it turned out that a simple adjustment of the rod connecting the slave cylinder and the lever arm at the bell house, as well as another bleeding of the hydraulic system solved the problem. It is possible to extend the lenght of the rod by turning it and fasten it by the lock nut. I've extended the rod approx 5 mm and it works. It's now possible to engage 1st at stand still and also engage reverse without grinding. However, the slave cylinder rubber cover has almost disintegrated and a complete new slave cylinder assembly has been ordered and will be changed as soon as it arrives.
Thanks to all for your inputs.
Cheers
/Finn
Finn. 1973 Morgan +8. 1959 Austin Healey 3000 BN7 2-seater. 2009 Mazda MX-5 2.0 PRHT.
