6 members (Pittsartist, nick w, nestor59310, MJF, DaveW, +8Rich), 306 guests, and 44 robots.
+8Rich 94
Posts837,271
Page 4 of 5 1 2 3 4 5
I see you have a charger socket wired under the dash, did you know you can use the existing 12v power socket and save having a dangling wire
Car came with it installed this way but thank you - useful to know 👍
2017 M3W
The car and bin looks great! I need to order mine.
Craig - Texas, USA
2026 Plus Four
2021 M3W
Not wise to use cigar lighter socket for charging due to possible poor connection, volt drop etc. The extra one appears to be non-reversible thicker cable connector dedicated to charger and often supplied with them for easy hookup, hopefully wired direct to battery.
The cigar lighter should be fine for the trickle charging you want for battery maintenance, as the current is so low. I would not use it for faster charging.
2020 M3W
I have been using the cigarette lighter for trickle charging my LiOn battery for a couple of years now without any problems.
Tested mine today. Perfect size for my phone but will need some double sided tape to keep it in place smile
I use the same direct connection to the battery for charging, there have been a number of recorded instances of fires as a result of using the cigarette or accessory points especially when left unattended and unfused. Not in M3Ws as far as I know but why take the risk.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Rodger
2004 Plus 8 (wife's)
1 member likes this: LightSpeed
Thanks for the great fond memories living on the Big Sur Coast while in college Roger. Made my day.
