8 members (CooperMan, Pigiron, Gordon D, G Walker, rory kim, MJF, ScottMellor, DrFitz),
192
63
Posts837,264
Posts: 62 |
I see you have a charger socket wired under the dash, did you know you can use the existing 12v power socket and save having a dangling wire
Posts: 32 |
I see you have a charger socket wired under the dash, did you know you can use the existing 12v power socket and save having a dangling wire Car came with it installed this way but thank you - useful to know 👍
2017 M3W
Posts: 492 Likes: 11
Posts: 492 Likes: 11 |
The car and bin looks great! I need to order mine.
Craig - Texas, USA 2026 Plus Four 2021 M3W
Posts: 8,655 Likes: 407
Posts: 8,655 Likes: 407 |
I see you have a charger socket wired under the dash, did you know you can use the existing 12v power socket and save having a dangling wire Not wise to use cigar lighter socket for charging due to possible poor connection, volt drop etc. The extra one appears to be non-reversible thicker cable connector dedicated to charger and often supplied with them for easy hookup, hopefully wired direct to battery.
Posts: 296 Likes: 3
Posts: 296 Likes: 3 |
The cigar lighter should be fine for the trickle charging you want for battery maintenance, as the current is so low. I would not use it for faster charging.
2020 M3W
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
I have been using the cigarette lighter for trickle charging my LiOn battery for a couple of years now without any problems.
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
Tested mine today. Perfect size for my phone but will need some double sided tape to keep it in place
Posts: 2,221 Likes: 180
Posts: 2,221 Likes: 180 |
I use the same direct connection to the battery for charging, there have been a number of recorded instances of fires as a result of using the cigarette or accessory points especially when left unattended and unfused. Not in M3Ws as far as I know but why take the risk.
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
1 member likes this:
LightSpeed |
