Morgan Aero 8
2 members (TBM, Image), 237 guests, and 78 robots.
+8Rich 77
Topics49,870
Posts837,670
Rudolf
Has any one experienced going into limp mode; switch off and on and the car recovers. Taken it to a Morgan dealer and can't find anything wrong
No fault codes stored?
No idea Richard haven't had it diagnosed yet
Was there any pattern to the occasions that it's gone into limp mode?
David
Aero S4
Smile, it confuses them
Your best bet is to start by buying one of the OBD scanners and pairing it to your phone to see what errors you are getting. If you are not confident with this then most local garages carry one of the snap-on scanners and will do a quick scan and give you a heads up for £50. Quick and a good place to start.
You might have something floating about inside the Mass airflow sensor this will give you the same fault, when you switch off the debris falls off the sensor back into the void. It's been discussed on here many times before an easy fix but buy the proper spray cleaner. Em
!10k boost mass flow air cleaner about a tenner. Em
Sir S1'a'lot
Sir S1'a'lot
Another one fir the MAF
2002 Aero 8 S1
2023 Plus 4 (woman’s)
Thanks everyone the car is going up to Richard Thornes and I hope they can diagnose the fault; already had a new Throttle Body lets hope it is the massflow sensor which doesnt look too expensive
The MAF sensor may just need a clean. Very easy to do yourself with the aerosol cleaner - click below.
I must admit have always found them perfectly clean though on a variety of car's.
