10 members (Zach, MATTMOG, sbarracl, CooperMan, Phil63, Topline123, RichardV6, Bunny, Black Adder, chanteclair),
318
Topics48,343
Posts813,019
Posts: 39 |
Has any one experienced going into limp mode; switch off and on and the car recovers. Taken it to a Morgan dealer and can't find anything wrong
Posts: 7,922 Likes: 217
Posts: 7,922 Likes: 217 |
Posts: 39 |
No idea Richard haven't had it diagnosed yet
Posts: 1,011 Likes: 31
Posts: 1,011 Likes: 31 |
Was there any pattern to the occasions that it's gone into limp mode?
David Aero S4
Posts: 11,221 Likes: 159
Posts: 11,221 Likes: 159 |
Your best bet is to start by buying one of the OBD scanners and pairing it to your phone to see what errors you are getting. If you are not confident with this then most local garages carry one of the snap-on scanners and will do a quick scan and give you a heads up for £50. Quick and a good place to start.
Posts: 2,383 Likes: 56
Posts: 2,383 Likes: 56 |
You might have something floating about inside the Mass airflow sensor this will give you the same fault, when you switch off the debris falls off the sensor back into the void. It's been discussed on here many times before an easy fix but buy the proper spray cleaner. Em
!10k boost mass flow air cleaner about a tenner. Em
Posts: 2,030 Likes: 10
Sir S1'a'lot Talk Morgan Expert
Posts: 2,030 Likes: 10 |
2002 Aero 8 S1 2023 Plus 4 (woman’s)
Posts: 39 |
Thanks everyone the car is going up to Richard Thornes and I hope they can diagnose the fault; already had a new Throttle Body lets hope it is the massflow sensor which doesnt look too expensive
The MAF sensor may just need a clean. Very easy to do yourself with the aerosol cleaner - click below. ![[Linked Image]](https://i.ebayimg.com/images/g/4gEAAOSwFKlfFwuz/s-l500.png) I must admit have always found them perfectly clean though on a variety of car's.
