4 members (paulmog, RichardV6, bmgermany, Nickplus4), 369 guests, and 51 robots.
+8Rich 91
Topics49,841
Posts837,318
Landy Offline OP
So, my 2018 M3W had its MoT today. 30 mile journey home no problems but as I pull in to the drive the revs start to drop and engine cuts out. It won't restart. It turns over fine but not firing up at all. Plenty of fuel in the tank. No previous engine issues. 3,900 miles Only.
So what is the sequence of checks? Is it the dreaded fuel pump?
Any help much appreciated! thumbs
Can you hear the fuel pump running when you switch the ignition on? If not check the cutout switch - a black rubber button to the right hand side of the back of the oil tank.
Red Leader drive
1 member likes this: Landy
Landy Offline OP
I checked the switch, no obvious click or depression when pushed.
I'm really not sure if I can hear the fuel pump behind me. I can here something at the front.
Get a new Walbro fuel pump.
Landy Offline OP
So, just looking at it now everything has cooled.
Fuel pump fuse OK!
Opened the boot and nothing obviously loose.
Turn ignition key and I can hear the pump energising. Engine now starts.
Switch off and on again, engine starts but idles for a few seconds then stops.
Ignition on again and no pump energising.
So is it definitely the pump or is there anything else to rule out before I start ordering the bits?
start with the pump
Rodger
2004 Plus 8 (wife's)
All the symptoms of a bad fuel pump, if you have a fuel pressure gauge there is a schrader test port on top of the engine, it should be a steady 58psi.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
+1 and I'll add that the 58psi needs to be with the engine running. With the ignition on but engine off, the pump runs for a few seconds and may appear to come up to pressure but with the engine running and a dodgy pump it can't maintain the pressure hence the cutting out.
Have been there, and have just bought another pump as a spare.
Fuel pump fuse OK!
99% the pump but the pressure check Rog suggested would confirm it. I would change the pump for the Walbro anyway
Red Leader drive
Have you replaced the fuse? A fuse can look OK and test OK, but can develop a hairline crack which will open up under load.
