2 members (bmgermany, MJF),
384
45
Topics49,841
Posts837,318
Posts: 141 Likes: 3
Posts: 141 Likes: 3 |
Thank you Gentlefolk for your input.
I have ordered the kit from Glencoe, spoke to Robert who was very helpful. Also ordered the Mahle KL167 fuel filter to replace at the same time.
This mornings job was to thoroughly clean the boot in preparation. I have printed the comprehensive instruction sheet by Ian and Andrew and read every thread I could find on the subject. Now to wait for the parts to arrive.
Posts: 141 Likes: 3
Bugger! I installed a new pump and filter as per guidelines. It started almost first go then stopped after about 4 seconds. Won't restart. Checked the 15 amp fuse again and this time it's blown!
So what now? Is there a starter relay? Something else that stops the pump energising? I heard it when it started. 😫ðŸ˜
Posts: 141 Likes: 3
Two notes to self:
1. Ensure fuel lines are connected correctly to fuel filter!! 2. Do not allow bare leg to come in to contact with exhaust pipe!
She Lives again!
Posts: 296 Likes: 3
Posts: 296 Likes: 3 |
Do not allow bare leg to come in to contact with exhaust pipe! I know your pain!
2020 M3W
Posts: 399 Likes: 15
Posts: 399 Likes: 15 |
Do not allow bare leg to come in to contact with exhaust pipe! I know your pain! Rite of passage for all M3W owners....
Posts: 492 Likes: 11
Posts: 492 Likes: 11 |
Do not allow bare leg to come in to contact with exhaust pipe! I know your pain! Rite of passage for all M3W owners.... My leg scar is from day two of M3W, when removing the bonnet to show a family member after a ride. Now I just try to keep others from doing the same.
Craig - Texas, USA 2026 Plus Four 2021 M3W
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
The mark of a true owner, you only do it once.
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
The mark of a true owner, you only do it once. Not so, I've done it twice...........
Red Leader
Posts: 360 Likes: 36
Posts: 360 Likes: 36 |
So what now? Is there a starter relay? Something else that stops the pump energising? I heard it when it started. 😫😠Check cables that are routed under battery tray - they go to the pump kill switch and can wear thru - check in low light levels and you might see the flash! Blows fuse intermittently depending on engine vibrations...
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
Hi Landy, does it start ok then stops as soon as the engine is under load? Then won't start? Leave it an hour and starts ok then repeats process? That's a faulty crank sensor.............
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
1 member likes this:
Landy |
