Topics48,362
Posts813,331
Members9,215
Posts: 12 Likes: 4
Posts: 12 Likes: 4 |
I appreciate this an old post but I’m about to change the perished bushes for polyurethane bushes on my Morgan +4 T16 (1996). Everything is exposed and I’m ready to go but I was just wondering are there any factory torque settings for the bolts associated with the bushes. Any advice gratefully received.
Best
Gwyn
Posts: 764 Likes: 8
Posts: 764 Likes: 8 |
Hi Gwyn, having done this job way back in the dark ages I would say just pinch up the bolts tightly, the factory bushes were rubber, yours are poly so torque could be different anyway even if there was one?
1993 T16 +4 Lancia Blue.
Posts: 12 Likes: 4
Hi JBK…that’s good advice and a fair point regarding the different materials. Thanks very much, I’m grateful 😊.
Best
Gwyn
Posts: 7,941 Likes: 218
Posts: 7,941 Likes: 218 |
Best
Gwyn I would have expected the bushes would have metal inserts that securing bolts tighten against, making bush material irrelevant to bolt torque. Assuming this is the case just nip up tight as suggested above.
Posts: 296 Likes: 4
Posts: 296 Likes: 4 |
Yes RichardV6, I believe they are called crush tubes. They determine the distance between the remote and the gearbox faces. So, as you say, tighten up until you feel it "bottoming out". If the crush tubes are long you may need an extra plane bush in addition to the lipped one before you feel the resistance on tightening the bolt. Some Loctite or similar might be a good idea as there are no lock washers used on these bolts.
1994 +8, BMW Calypso Red. 2002 4/4, 4 seater, BMW Calypso Red. How do you open the boot?
