3 members (RedThree, IcePack, Lordofthewings), 304 guests, and 39 robots.
John V6 79
+8Rich 70
DaveW 68
9,203 Registered Users
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Goggle eyed
by Roady - 19/07/25 06:16 PM
by t50 - 19/07/25 12:07 PM
Lions Tour
by OZ 4/4 - 19/07/25 11:55 AM
Morgan rebuild on Facebook
by TBM - 19/07/25 10:50 AM
Topics48,337
Posts812,933
Members9,203
toitoine
Page 3 of 3 1 2 3
I appreciate this an old post but I’m about to change the perished bushes for polyurethane bushes on my Morgan +4 T16 (1996). Everything is exposed and I’m ready to go but I was just wondering are there any factory torque settings for the bolts associated with the bushes.
Any advice gratefully received.
Best
Gwyn
jbk Offline
Hi Gwyn, having done this job way back in the dark ages I would say just pinch up the bolts tightly, the factory bushes were rubber, yours are poly so torque could be different anyway even if there was one?
1993 T16 +4 Lancia Blue.
Hi JBK…that’s good advice and a fair point regarding the different materials. Thanks very much, I’m grateful 😊.
Best
Gwyn
Best
Gwyn
I would have expected the bushes would have metal inserts that securing bolts tighten against, making bush material irrelevant to bolt torque. Assuming this is the case just nip up tight as suggested above.
Yes RichardV6, I believe they are called crush tubes. They determine the distance between the remote and the gearbox faces. So, as you say, tighten up until you feel it "bottoming out". If the crush tubes are long you may need an extra plane bush in addition to the lipped one before you feel the resistance on tightening the bolt. Some Loctite or similar might be a good idea as there are no lock washers used on these bolts.
1994 +8, BMW Calypso Red.
How do you open the boot?
Page 3 of 3 1 2 3
