Morgan Aero 8
4 members (CooperMan, TalkMorgan, John Winn, sprinty), 166 guests, and 73 robots.
+8Rich 66
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,878
Posts837,748
#786558 28/09/23 12:26 PM
PH1954 Offline OP
hi Guys Have a 2004 series 1 aero
That wont start left idle for 3 years
Checked pump in tank wont work
removed pump ran on external supply works fine
Help
Might as well clean the tank while the pumps out . Fit and replace if it works on the bench finniky things pumps when their left for a while . Change the fuel filter petrol these days don't like to be left 3 yrs is a long time. Em
Sir S1'a'lot
Sir S1'a'lot
Bad earth?
Don’t let it spark ;(
2002 Aero 8 S1
2023 Plus 4 (woman’s)
Duff relay or fuse?
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Suggest changing fuel pump relay as a starting point. I think they are colour coded as to type/purpose on Aero's. This should do the job.
PH1954 Offline OP
Thanks guys
Aerotaff have cleaned out tank as I had to to remove pump
Deejay have checked fuse and will check relay tomorow
Viper you are so right
I thought there was a separate ECU as per the X5 the v8 engine an electronics came from can’t find it any where
Thanks for your help keep it coming
Paul. If you open driver side Bonnet there is an ali box with allen screws,open the box and you gain access to the electrical bits this gets really hot when driving also water can dribble over the box allthough dry inside you can get condensation from the louvres. It's worth pulling the fuses and relays out for a clean. most of the electrical gremlins on the series 1 starts here good luck. Em
PH1954 Offline OP
Thanks aero taff
Have the lid off to check the fuses and has not .been out of my workshop for several years
So I do think it’s water does anybody know where the fuel pump ECU is located
Thanks
Likely the fuel pump relay will be next to fuses alongside all the other cube shaped plug in relays.
Further help in relay location. Below is image of Aero Plus 8 electrics box under bonnet, yours will be similar.
More here. The fuel pump relay will likely be one of the bank of light green ones labelled "25".
Fuel pump fuse is F37 20amp in block of 29 as displayed on electrics box cover of Aero S1 below.
