7 members (Moggo, Nickplus4, RichardV6, Strathaven, Alan Patterson, Simon, DickJ), 242 guests, and 56 robots.
+8Rich 73
DaveW 52
Topics49,867
Posts837,619
Moggo
#788589 24/10/23 01:03 AM
mon32 Offline OP
I have a 1932 morgan three wheeler in Japan.
What is the tightening torque value for the tyre bolts?
Tell me about it.
Best regards.
Online NoMood
Torque values were not published in 1932 and for many years afterwards. Tighten them but not so much you cannot undo them later.
Depends what wheels you have.
For a 1932 R type you should have late 2 speeder wheels.
4 stud Dunlop Magna wheels came in for the 1933 model year. They don't need an awful lot of torque
Also check them very carefully for cracking between the stud holes and any signs of the wheel pulling over the wheel nut
Arwyn
mon32 Offline OP
Dear RichardV6,
Dear Arwyn Williams
Thank you very much for your answer.
The tightening torque for the tyres was set to 40 Nm, based on your opinion.
mon32
1932 M3W supersports beetle back
X
X
About torque: modern cars the wheels must been fixed with 110/120NM (Volkswagen) or the new Mini up to 140NM.
The classic old Mini and Triumph Vitesse the wheels are only fittes with 65NM!
So I think you are more in the lower range. Or as „MWS“ (manufacturer of the new wirewheels) says: don‘t tight them overethusiaric.
Greets René
2018 plus4 (sports green)
TBM Offline
Less is more when it comes to Morgan wheel studs. On my 72, although the wheel studs are an M14m they screw into the hub with little more than an M8 fitting (or Imp equivalent) so are very easy to snap.
The other thing to realise is vintage three wheeler hubs are awfully brittle, especially more so as they get older.
Arwyn
mon32 Offline OP
Dear xc68anc
Dear TBM
Dear Arwyn Williams
I thought a normal car would have around 100Nm, but when I measured the torque on one wheel of the M3W, it was 40Nm.
It's difficult, isn't it?
mon32
TBM Offline
I don't use a torque wrench. I do them up by 'feel' (although did once go too far and snapped a stud). I check them regularly to make sure they are still tight (and they usually are).
mon32 Offline OP
Dear TBM
It's important to have a feel for it.
I'm new to pre-war cars, so I would have liked to know the tightening torque, if it was available.
mon32
