8 members (DPEvans, Rovert, MartO, Ritchie B, +4competion, +8Rich, JohnHarris, Alan Patterson),
243
48
Posts837,259
Posts: 26 Likes: 3
Posts: 26 Likes: 3 |
As the title because a search has not throw up any results.
Can I fit Morgan plus 4 size tyres on my 2013 Morgan 4/4 wire wheels with no clearance issues
Thanks in advance
Dale. South Yorkshire.
2013 Morgan 4/4 Darth Vader Black.
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
Be careful because the 4/4 wire wheels have slightly more inset than Plus 4 and Roadster wires. The narrow bodied Plus 4 comes with 185/70 Avons, but clearance to the spring mount at the top of the crosshead is 2 or 3mm.
I tried 185/70 Blockleys but they fouled the spring mounting. So I think you should be Ok with a 175, but 185 is brand specific, so get the front clearance checked.
Posts: 5,464 Likes: 171
Posts: 5,464 Likes: 171 |
Why would you want to change the profile? The standard profile works really well as long as you choose the right tyre’s Vredestein T Trac2 for example.
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
Why would you want to change the profile? The standard profile works really well as long as you choose the right tyre’s Vredestein T Trac2 for example. Also my opinion. IMHO the (small) T-Track 2 are the best choice on dry and wet roads and don't need to much power in the steering.
Posts: 1,242 Likes: 30
Posts: 1,242 Likes: 30 |
I run 175/70/15 on my 4/4. To me best comprise. To me they fill the arches well & look proportionate.
Posts: 26 Likes: 3
The tyres on at the moment are 165-15 with some very expensive Avons on the front and Continentals on the rear and I’m going to fit a matching set of 4 but wondered what other people have tried and found to be good.
Posts: 5,586 Likes: 603
Posts: 5,586 Likes: 603 |
Another vote for T-trac 2 .... good tyres without breaking the bank
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
It seems to me that your front tires have more grip than the Continental in the rear. The Continetal have "negative grip", so to speak. This is not a good idea and could cause you to lose the rear. I will be buying my third set of T Track next spring, no desire for wider tires for my 2014 4/4 with 145 hp. I was thinking 175/70, but really just out of curiosity, the 165/80 just fit the 4/4 very well. It should be four of the same and new tires no matter what size.
Posts: 26 Likes: 3
A full set of T-Trac 2 tyres it is then.
The Avon in question are the CR11
Thank you
Posts: 2,273 Likes: 38
Posts: 2,273 Likes: 38 |
T- Trac 2 tyres made a massive improvement over the original continentals ![[Linked Image]](https://tm-img.com/images/2023/07/08/2D8F4283-AF94-4F05-8869-93B0EA7D9E98.jpeg)
Craig Jezz
