1 members (Alastair), 319 guests, and 37 robots.
+8Rich 94
Posts837,276
#789709 10/11/23 02:07 PM
DRC72 Offline OP
As the title because a search has not throw up any results.
Can I fit Morgan plus 4 size tyres on my 2013 Morgan 4/4 wire wheels with no clearance issues
Thanks in advance
Dale. South Yorkshire.
2013 Morgan 4/4 Darth Vader Black.
DRC72 #789723 10/11/23 04:50 PM
Be careful because the 4/4 wire wheels have slightly more inset than Plus 4 and Roadster wires. The narrow bodied Plus 4 comes with 185/70 Avons, but clearance to the spring mount at the top of the crosshead is 2 or 3mm.
I tried 185/70 Blockleys but they fouled the spring mounting. So I think you should be Ok with a 175, but 185 is brand specific, so get the front clearance checked.
DRC72 #789725 10/11/23 05:30 PM
Why would you want to change the profile? The standard profile works really well as long as you choose the right tyre’s Vredestein T Trac2 for example.
Costock, UK
Disco 5
Paul F #789726 10/11/23 06:00 PM
Also my opinion.
IMHO the (small) T-Track 2 are the best choice on dry and wet roads and don't need to much power in the steering.
DRC72 #789733 10/11/23 07:33 PM
I run 175/70/15 on my 4/4. To me best comprise. To me they fill the arches well & look proportionate.
DRC72 #789737 10/11/23 08:40 PM
DRC72 Offline OP
The tyres on at the moment are 165-15 with some very expensive Avons on the front and Continentals on the rear and I’m going to fit a matching set of 4 but wondered what other people have tried and found to be good.
DRC72 #789738 10/11/23 09:09 PM
Another vote for T-trac 2 .... good tyres without breaking the bank
DRC72 #789744 10/11/23 11:18 PM
It seems to me that your front tires have more grip than the Continental in the rear. The Continetal have "negative grip", so to speak. This is not a good idea and could cause you to lose the rear. I will be buying my third set of T Track next spring, no desire for wider tires for my 2014 4/4 with 145 hp. I was thinking 175/70, but really just out of curiosity, the 165/80 just fit the 4/4 very well. It should be four of the same and new tires no matter what size.
DRC72 #789940 13/11/23 08:46 PM
DRC72 Offline OP
A full set of T-Trac 2 tyres it is then.
The Avon in question are the CR11
Thank you
DRC72 #789943 13/11/23 08:59 PM
T- Trac 2 tyres made a massive improvement over the original continentals
Craig Jezz
