0 members (),
266
91
Topics49,870
Posts837,668
Posts: 54 Likes: 27
Posts: 54 Likes: 27 |
Posts: 28,904 Likes: 352
Posts: 28,904 Likes: 352 |
I've seen that car at several events over the years - the reg stands out!  I hope the weather picks up a bit for you to get out and enjoy your new car very soon!
1 member likes this:
Beard |
Posts: 141 Likes: 2
Posts: 141 Likes: 2 |
Welcome to Aero ownership "Beard". A niche within a niche  which can become an addiction! Looks like you have a fantastic example and you're going to find it's like dating a super model as the car will always get a lot of positive attention so enjoy....just remember it's the car not you
AnDrew G 2003 Aero S1 - past 2009 Aeromax - past 2012 +4 Supersport - past 2008 Aero S4 -past
Posts: 54 Likes: 27
Good advice I'm sure! One question for you, and I'm assuming your Aeromax is the same as my S4 in this regard, the manual appears to show that there is a boot opening switch/button inside the car behind the seats (i.e. a fail safe in case you don't have the key in the ignition I'm assuming. I can't find it anywhere - does this switch/button actually exist? Best regards Beard
Posts: 1,079 Likes: 71
Posts: 1,079 Likes: 71 |
Hi Beard, it's an entirely manual system using a leather tab attached to a cable running to the boot catch. Just lift the tab off the popper and give it a pull, mine needs quite a tug.
David Aero S4
Posts: 54 Likes: 27
Many thanks David - I shall take another look for it! Much appreciated. Beard
Posts: 141 Likes: 2
Think your question was better answered below from David. The Aeromax has the butterfly windows on an actuator (and I've never wondered or looked at the manual on this or my previous S4 to see if there's a manual release...damn now I going to have to look.).
Posts: 54 Likes: 27
I've just found the boot release - nowhere near the position indicated in the manual - it is behind the driver's seat roughly level with where my right shoulder would be when driving. It works well I'm pleased to report - good news as the car is currently connected to a CTEK charger so I can't get in to the boot otherwise - although I think we have some sunshine coming this weekend, so I suspect all will be re-connected and a drive will be on the agenda. Best regards Beard
Posts: 1,646 Likes: 1
Posts: 1,646 Likes: 1 |
That is my old Aero. It wasn’t a rebuild in the ‘engine’ sense. The chassis and suspension was damaged and a new chassis and suspension etc was fitted which meant completely dismantling the car and starting afresh on the new chassis.
Mileage is not correct, car had a replacement speedometer under warranty around 10-12,000 miles in. It had done circa 80,000 in total when I sold it.
Aero 8 GTN. #10
Posts: 2,033 Likes: 23
Posts: 2,033 Likes: 23 |
Welcome to the forum! Lovely car and enjoy.. when the weather picks up.
Aero 8 GTN #11
