4 members (Graham, G4FUJ, stumog, Plus Four Guy, Saxonian), 190 guests, and 50 robots.
Posts837,249
#792387 19/12/23 03:29 PM
jonm Offline OP
Hi all,
The horn on my Roadster became weedy last night, probably a loose connection due to either damp or vibration. However, I've had a search under the bonnets and can't find it - all clues to its location gratefully received.
4-seater V6 3.7 Roadster.
jonm #792388 19/12/23 03:45 PM
On my 2014 4/4 it is underneath the lower panel in front of the radiator.
Costock, UK
Disco 5
jonm #792389 19/12/23 03:46 PM
Formerly known as Aldermog
Mine were under the front of the wings, going weedy was in my experiennce, down to getting water inside....
jonm #792390 19/12/23 04:10 PM
Either above or below the panel by the cowl brhind the grill and before the rad. They normally get rusty but can be rebuilt, I keep a spare set and swap them over.
You may be able to get you hand in but if the rad is close you need to remove the cowl.
jonm #792393 19/12/23 04:34 PM
There should be two horns on a Roadster Jon, high and low note located under the tray at bottom of grill, or above if spoiler fitted. If either fail you will be left with a seemingly weak single horn. If you remove the number plate support (two bolts after removing plate) the grill will drop out also and access will be easy from below or above.
Had to change one on our Mini recently for same reason, not the easy to access one of course doh
I wouldn't bother trying to rebuild the OE horns. They are sold as matching pairs on eBay for peanuts. Might be an opportunity to upgrade to relay operated air horns though.
jonm #792398 19/12/23 05:30 PM
This is what they'll look like inside, very easy to strip, dry out and clean all the crud off the diaphragm
jonm #792428 20/12/23 12:18 PM
jonm Offline OP
Many thanks, found the horns (not visible from anywhere other than directly underneath when you have a Mulfab radiator) and checked the connections, plus a judicious application of WD40 and all seems to be sorted for now.
All the above advice taken on board for the eventual failure.
jonm #792432 20/12/23 02:25 PM
I fitted mine here
Craig Jezz
jonm #792438 20/12/23 03:47 PM
A lot of these horns give up due to water ingress through the trumpet onto the diaphragm. Although it might seem best to point the trumpet directly forwards, that is laying it open to flooding, especially if the horns are down underneath. After my first horn drowning, I angled mine away from pointing forward and have had no problems since the past 10 years or so. The sound still gets out well enough.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
jonm #792455 20/12/23 06:07 PM
Agreed Doug. A near right angle bend in those brackets would have sorted it as well.
