6 members (Zach, piquet, Chris Cosher, gaston, TigerTim, Hamwich), 360 guests, and 51 robots.
+8Rich 92
Topics49,838
Posts837,294
#793901 15/01/24 08:04 PM
HIND Offline OP
About to replace my fuel filter with a MAHLE unit as part of my service. Looking at the existing set up I am not familiar with the the type of pipe to filter connectors, are these some sort of push on connector and is a special release tool required?
Gordon
2013 M3W
1972 MGB Roaster
1967 Morris Mini Super Delux
No special tool is required, there is rectangular button to press use fingers or flat bladed screw driver to depress and pull hose off whilst depressed, to refit just push on and they will lock in place.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
HIND Offline OP
Thanks Rog G That looks simple enough.
Is the fuel system under any sort of pressure or is it just do a you say.
Gordon
2013 M3W
1972 MGB Roaster
With fuel injection systems, run the engine and remove the fuel pump fuse whilst it is running.When the engine dies to a stop, pressure will have been released.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
On the M3W the residual pressure is minimal, I have changed many fuel pumps and filters without worrying about the pressure
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
HIND Offline OP
Many thanks for advice now to change the filter.
Gordon
2013 M3W
1972 MGB Roaster
Immediately after shutdown, there will be about 58psi of pressure. After sitting for a few hours, residual pressure should be zero.
Late 2012 M3W
HIND Offline OP
Thanks for the update Steve
Gordon
2013 M3W
1972 MGB Roaster
Forgot to mention that you can also depressurize using the schrader valve on the one fuel injector bracket (engine not running of course!). Hold a rag around a small screwdriver or similar and press the valve down. Gives more control over containing fuel spray than opening a fuel line elsewhere.
Late 2012 M3W
When you fit the new fuel filter it's well worth isolating it from its bracket with some insulating tape or similar to prevent Galvanic corrosion. More details in THIS THREAD.
Andy
