9 members (bmgermany, IcePack, Morganmike, Gordon D, Bitsobrits, RichardV6, DaveW, Zach, MJF),
283
72
Topics49,861
Posts837,532
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
Advice please from some of you electronics wizards.
I've got a few wires to solder to some small connectors but my ancient soldering iron won't melt butter let alone lead free solder so I need to invest in a new one.
Question is what to buy. There is a bewildering choice from a few quid up to hundreds of pounds for professional soldering stations.
I'm thinking of tinkering a bit with electronics but not to any great level so not looking to break the bank with this purchase.
Any advice please on a basic but adequate soldering iron, does it need temperature control for example?
Also what are the best solders and fluxes to go for in the (very) amateur world?
Thanks in advance.
Bob
Posts: 308 Likes: 31
Posts: 308 Likes: 31 |
For 'traditional' car wiring (eg 1970s bullet/spade etc) and up to 30A wiring I would have thought an inexpensive 40W iron would be fine. And ordinary lead free fluxed solder: eg: https://www.toolstation.com/draper-soldering-iron-stand/p86557https://www.toolstation.com/lead-free-flux-cored-solder/p97854or with slightly more control - a manual temp control iron: https://www.toolstation.com/draper-soldering-station/p62910For more intricate stuff on pcbs say, or with delicate components, it is well worth getting a temperature controlled iron, with a mix of different bits. Professional units will cost £200 plus, https://uk.rs-online.com/web/c/?searchTerm=weller+soldering+station(While you might think you don't need a high power set up (eg 80W) for small components, that can be important if you are rapidly soldering a number of locations at once (eg a 40 pin IC). And a high wattage can also be useful if the thing you are soldering has a large thermal capacity (eg a bit lump of copper say). Investing in a good desoldering tool (eg something that will suck molten solder off a pcb or a connector when you are undoing something) is worth considering. I've just suggested some examples, but I'm sure there are plenty of equally good alternatives in the same price range.
Dave Blue 4/4 1969, Green +4 1953, (different) Green +8 1977
Posts: 8,675 Likes: 411
Posts: 8,675 Likes: 411 |
Have a look here. Weller used to be the soldering iron of professional choice.
Posts: 5,465 Likes: 171
Posts: 5,465 Likes: 171 |
I second the vote for Weller.
I spent a few very happy years using Weller Soldering Irons on an almost daily basis in the 1980's. The rest that stops you burning the bench (or yourself) between uses is invaluable. The temperature is controlled so they don't overheat.
I only have a very cheap soldering iron as it doesn't get a lot of use. The cheapest soldering irons do not have a thermostatic control worth talking about and some can overheat - I rest mine on a heat sink (vice or large hammer) between uses.
Posts: 1,984 Likes: 103
Posts: 1,984 Likes: 103 |
Oh dear, I seem to have strayed into a parallel universe and the "Least-frequently used tools" thread. My assorted soldering irons (mostly) get used on an annual basis, although I seem to be a bit behind in opening the silver-soldering kits. The Fluxite flux was my Dad's; last used in the early-60's ![[Linked Image]](https://www.tm-img.com/images/2024/02/06/Soldering--1.jpeg) ![[Linked Image]](https://www.tm-img.com/images/2024/02/06/Soldering---2.jpeg)
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Posts: 1,015 Likes: 119
Posts: 1,015 Likes: 119 |
Ah! The Henley solon ........ I'm still using mine that I bought 50 years ago!
Posts: 8,678 Likes: 491
Posts: 8,678 Likes: 491 |
I have a really old tin of Fluxite, and still use it sometimes
Posts: 51 Likes: 17
Posts: 51 Likes: 17 |
Can you take a photo of what you need to solder? Some terminals are solderless i.e. crimps.
2002 4/4 Zetec Indigo Blue purchased July 2023 my first Morgan
These are the terminals I have to connect. I'm almost certain they have to be soldered. Scale below in mm. ![[Linked Image]](https://tm-img.com/images/2024/02/07/IMG_3150.jpeg)
Bob
As an alternate to soldering you could use this crimp rouind head connectors and then connect the two with a small nut/bolt/washer ![[Linked Image]](https://tm-img.com/images/2024/02/07/roundhead-crimp-connectors.jpeg) This might be more convenient (but possibly less reliable) than soldering if you want the unit to be easily removable.
