4 members (Morganmike, Moggo, Alan Patterson, How), 270 guests, and 54 robots.
+8Rich 89
Topics49,841
Posts837,326
Christoph
Malakas Offline OP
All,
I drove my Super 3 yesterday in about 82 degrees (F) weather. A bit of stop and go traffic but also some cruising. Of note - I did my own oil change and switched to Mobile One Synthetic 5w-20 oil last week. Yesterday, usually when stopped at a traffic light, the car kept dinging with this error Morgan Overheat. Sometimes it would switch to a red version of the same warning for a few seconds - I'd hear a fan pop on, and then back to the yellow warning. As soon as I revved the motor, or drove away I could clear it.
My concern is that it is about to be a whole lot warmer here in Houston!! Has anyone else experienced this type of issue in the summer months?
2023 S3
I am assuming the coolant level is OK?
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Low oil pressure at idle? Might be worth checking that oil you used is recommended for that engine in those temperatures.
ford specifies 5W-30 (Castrol Magnetic WSS-M2C913-C) for the 1.5L Ecoboost, so might using 5W-20 be a bit thin when it warms up?
Think it needs to be at least a 15w40 for those ambient temperatures.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
I
I
The Morgan Super 3 Manual specifies Engine Oil . . . . . . . . . . . SAE 5W-20 In fact the same oil I use (specified) in my 2023 Ford Maverick Hybrid Non Turbo 2.5), my wifes 2023 Ford Explorer Ecoboost 2.3 Turbo uses 5W30 synthetic
If you’re idling frequently in an ambient temperature of 82 degrees F and overheating, then I would put 5w30 in. You’re not going to harm your engine, you will if your running too hot frequently with the 5w20.
The recommended oil viscosity for my 2015 M3W X Wedge is 20w50. My local bike shop is owned by a master mechanic who worked on the S&S racing development team. He told me they found big V twins frequently running hotter than originally thought so he recommends 20w60 for big V twins. I’ve been using 20w60 for years rather than 20w50 without any issues.
Also wondering if your coolant pump is working properly.
My 2 cents.
Malakas Offline OP
Thanks for all the replies! Going to re-check coolant this afternoon (I park at a remote garage / club).... if that ends up being the cause I'll send everyone on here a beer. Jeez.
Assuming coolant is good - great points made about the oil. The manual does state 5w-20 and Warren99 lives in Dallas and he said he never overheats on that oil. So maybe coolant pump, thermostat...?
Lucky for me car is going back to dealer for the mandatory brake recall so they can sort it out.
2023 S3
Malakas Offline OP
Sorry - no beers - coolant is full.
2023 S3
Are there ways to check for airlocks on the S3's twin radiator layout?
