1 members (Luddite), 297 guests, and 41 robots.
John V6 79
+8Rich 70
DaveW 68
9,203 Registered Users
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Goggle eyed
by Roady - 19/07/25 06:16 PM
by t50 - 19/07/25 12:07 PM
Lions Tour
by OZ 4/4 - 19/07/25 11:55 AM
Topics48,338
Posts812,937
Members9,203
PPP356
Page 3 of 3 1 2 3
Originally Posted by Ian Wegg
Richard: Well I did say I might confuse matters! I hadn't checked how the avatar setting worked, I thought it just stored the url. You are correct, the forum software checks the picture and therefore suffers the same .jpg / .jpeg bug of the galleries. All the while TM-img changes jpeg file extensions it can't be used to host avatars in that case.
Alistair: Yes I do onion gravy too!
Well I used Tm-img for my recent change Ian ! xmashappy this was over the weekend I think but I don't understand all these terms as I'm not an IT person.
2009 4/4 Henrietta
1993 Connaught Green +8 prev
I wonder if Peter / Tim are aware that TM-Img is now changing file extensions. That is a relatively new "feature" (as Microsoft would call it!).
'09 Gen2 MINI Cooper ragtop
1 member likes this: Heinz
From the other thread on the same subject at https://www.talkmorgan.com/ubbthreads.php/topics/795612/1
Originally Posted by Image Library
Until I saw this thread I was not aware of the problem.
I have just finished searching the forum on the developer's site ( https://chevereto.com/community/ ) and I found a reference that the extensions were changed to jpeg after the upgrade to version 4 to avoid problems relating to the jpeg extension and to avoid having two naming conventions for what are the same types of files.
Images uploaded before the change are not effected.
To me this is an error because the jpg file extension is the most common, furthermore the permited extensions include both types. I will report this to the developer as a problem that should be a user choice and, in the mean time, investigate the possibility to override this behaviour.
If it is causing a problem in individual cases I should be able to change the extention back to jpg manually.
TM Image Library was set up independently for the use of Talk Morgan forum members
This "feature" was introduced with version 4.0.4 which I installed about a year ago. Unfortunately it was intentional on the part of the developer in order to "standardise" the JPEG file type extension. Since a) the jpg extension is the more common type, and b) in order to support files uploaded before the version 4.0.4 (we are now at V 4.0.10) both .jpg and .jpeg files are supported I can not understand the need to convert the file extensions.
Unfortunately the code is very complex and I have had no success in finding the section where the file name extensions are changed.
I have registered some feedback to the developer.
2 members like this: Graham, G4FUJ, Alistair
Just to give a further update on this question for those who have an interst in technical issues.
I have now located the section of the code which converts the file extension from .jpg to .jpeg. I have also understood the method used.
The background of this is that original versions of windows required a 3 letter extension whereas other operating systems could use a 4 letter file extension. All operating systems now have the capability of using a 4 letter extension however the 3 letter .jpg extension remains the most commonly used.
For the moment I have returned to the original convention. That means that the rare files that are uploaded with a .jpeg extension will be converted to .jpg
Unfortunately the code is quite complex and I have not been able to make it function so that the original file extension, be it .jpg or .jpeg, is retained, the way the code works it must be one or the other.
For the moment any files uploaded with either .jpg or .jpeg extensions will have the .jpg extension which will allow them to be used as an avatar (unless the file size is small I would recommend using the thumbnail).
For the moment this means that a small change will need to be made in the code every time there is an update. I hope that in the future the developer makes a change which allows both extensions to be retained. The question also remains that perhaps UBB.threads (the software used by this forum) should update their code to support both extensions too.
2 members like this: Jon G4LJW, Graham, G4FUJ
Black Rat
Black Rat
To me that makes as much sense as Chinese instructions on a flat pack rofl however thanks for all your efforts.
Signed,
A Technophobe.
Keith
2013 narrow bodied + 4 Ruby.
Well done Peter! thumbs
Page 3 of 3 1 2 3
