2 members (Soleng, Zach), 372 guests, and 52 robots.
+8Rich 91
Topics49,841
Posts837,316
Lance Offline OP
Replaced a seized rear brake cylinder on my 2016 three wheeler.
Bled the brakes. Brakes are good, but the "brake failure" light will come on and flash a few times ever once in a while.
I don't have to be braking for the light to come on.
master cylinder is full. What triggers this light and what is it trying to say.
Thanks
Lance
1981 Plus 8
2016 Three Wheeler
2022 Corvette Stingray Convertible z51
The cap of the master cylinder has a float switch which will trigger if the brake fluid is too low, also check the electrical connectors to the cap.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
If the fljid is to low in the reservoir it will come on intermittently.
And find out where the fluid is going?
Well, add a bit more and keep an eye on it.
Lance Offline OP
Reservoir is full
Lance
1981 Plus 8
2016 Three Wheeler
Check the brake light switch. I don’t know which type is on your car or where it is. My Plus8 had a hydraulic switch in the pipework. Pressure increase from the pedal pressing activated it. My brake lights were intermittently lighting up when not braking. Brakes worked ok and no leaks. I the switch and all ok. Yours is likely to be an electric switch triggered by the pedal.
I used to have a hydraulic brake light switch on a previous car and they didn’t seem to last as long as a mechanical switch.
I know nothing of the M3W, though some brake fluid reservoirs have a probe which can detect some degree of condensation (water) in the fluid to indicate it is time for a fluid change... Just thinking in type, and hoping not to add to any possible confusion.
Lance Offline OP
How does the brake failure light on the M3W function. Does it only detect fluid levels in the master cylinder or does it function in some other manner?
Lance
1981 Plus 8
2016 Three Wheeler
To check the brake light, disconnect a wire on the brake fluid level cap, it should go out, if it does not go out, see the handbrake switch, similarly unplugged or connected the two electrical plugs to see if this turns off the signal, if this does not solve the problem and the brake fluid level is good the problem is electrical so you can drive.
