Topics49,863
Posts837,549
Posts: 85 Likes: 18
Posts: 85 Likes: 18 |
Hello
I have some difficulty to put the steel profile of the capote on the windscreen correctly. Maybe is the rubber I have to change? I need 1cm to push it. Thanks for your reply
Posts: 8,677 Likes: 412
Posts: 8,677 Likes: 412 |
If it's the hood header rail you are referring to, check the rubber in inverted U section of rail. Mine got folded back on itself on one side making fitting difficult. A new seal cured the problem but all old glue must be removed with solvent then seal fitted with industrial grade glue.
Posts: 85 Likes: 18
Ok I will check it. Thanks
Posts: 85 Likes: 18
The rubber is like new, but it is too hard to get the steel profile correctly on the windscreen.
Maybe I have to lube the rubber and also the windscreen?
I need an instructor....
Posts: 1,984 Likes: 103
Posts: 1,984 Likes: 103 |
Make sure that when you replace or improve the rubber seal, you pack it out the correct width to match the screen frame (as I did when fixing it on my Roadster). ![[Linked Image]](https://www.tm-img.com/images/2024/02/29/Hood-header-rail--2.jpeg)
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Try some talcum powder on seal to ease fitting if it appears undamaged. Some lubes may damage rubber!
Posts: 27,813 Likes: 749
Posts: 27,813 Likes: 749 |
Daft question but have you released it at the rear via the catch?
Here is a video of how it should work Hood video
Posts: 85 Likes: 18
Sorry I inspected the rubber and I saw some parts are a little take off. It is also hard. I think I need a new one, is it usual after 10 years but only 18500 km?
Posts: 2,093 Likes: 74
Posts: 2,093 Likes: 74 |
Sorry I inspected the rubber and I saw some parts are a little take off. It is also hard. I think I need a new one, is it usual after 10 years but only 18500 km? Mine is 13 years old and still good. You do not say where you live. I think maybe Europe? If so, it could have deteriorated from UV effects of strong sunshine?
